I need to clean up some chrome on a special fork. Suggestions?
super fine brass wool available at your local marine supply will be the gentlest to minimize scratching of the chrome. Follow up with a liberal polishing with autosol and a clean soft cotton rag. Some will jump in and say oxalic acid. You could try that too.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
That's looks like a fairly easy cleanup. Water and 2k sandpaper or maybe 1500 would also work. I think the 0000 steel wool falls between them in terms of grit.
I have heard but not tried foil. I really should, if you do let us know how it goes.
Bikes: 99' Torelli Nitro Express, 90' Miyata 414, 09' Guru Evolo, Eigthinch Scrambler
on what Bikerider007 said, use aluminum foil, ball it up dip in some water and scrub on the chrome, the aluminum is harder than the rust but softer than the steel chrome so the surface rust will be removed and the chrome not scratched. scrub until it feels really smooth and you get little if any resistance. Works really well, I was surprised the first time I tried it, cheap and easy.
Why not just soak it in an OA bath? Or some Evaporust?
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Liked 636 Times
Once you get it clean, wax it regularly to keep the rust at bay.
52psi
Liked 803 Times
I too was surprised. The rust just disappeared, and this was on a '64 Schwinn from a back yard in Portland, OR. If it can handle that...
Liked 2,265 Times
OA is a minimum of effort with the greatest return and least opportunity for added damage. Plus it takes care of the areas you can't reach or see.
Old fart
Liked 3,479 Times
tantum vehi
Liked 999 Times
+1 if you don't want to remove the fork. Brass wool is better than steel in cases of rust - you don't want fine particles of steel left behind that can rust. Brass won't rust. Wax on, wax off. You might also try Brass Monkey during the process.
I shall do the OA bath followed by foil ball, then go up the hardness scale if needed.
Any old car wax suitable for coating the cleaned chrome? I usually use Nu Finish on bike frames (minimal scrubbing since it will remove some paint if you provide the elbow grease)
I already have this on hand. Think it's ok to sub for OA? I only worry because it seemed to have flaked the chrome off of some bolts and a Campy pump mount before... But it does get rid of/convert rust.
I also already have Naval Jelly...
https://www.rustoleum.com/~/media/Di...olver_TDS.ashx
Soma Roark
Classic & Vintage
5
08-23-11 08:35 PM
Mr_Christopher
Classic & Vintage
3
12-19-09 07:48 AM
