Best gear ratio
Calamari Marionette Ph.D
Since my legs, heart, and lungs are exactly identical to yours, you should use the same ratio that I do.
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
42. The answer to life, the universe, and everything.
But seriously, this may be of help.
Single Speed Gearing 101 | Spews | The Information Hole | Surly Bikes
Suppose I'll be helpful. Not because I want to, but because I can't think of anything clever.
Thinking in gear inches would be more helpful than thinking about a gear ratio to start off with. For commuting on flat city streets I would suggest any gear ratio that will give you 60 - 75 gear inches depending on if you are riding fixed or single speed and your fitness level.
Use this website and some trial and error to find out what you prefer: BikeCalc.com - Fixed Gear Calculator
It would also help us to know anything about current bikes you ride.
#KiloTT
Edit: Wanted to post this too.
#KiloTT
Quoted: 481 Post(s)
Liked 131 Times
working on my sandal tan
Quoted: 3874 Post(s)
Liked 2,576 Times
Welcome to BF! The answer is in here: https://www.bikeforums.net/singlespee...mer-newbs.html
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Mathematics is not something to joke about.
I agree with @Carcosa. 60 to 75 gear inches is a good place to start and adjust from there depending on terrain, strength and masochistic tendencies.
-Tim-
-Tim-
Bikes: Salsa Fargo Ti, Cannondale CAAD9, Carbonello Fixed Gear, Specialized Epic Disc
Quoted: 39 Post(s)
Liked 16 Times
What speed do you ride at the most? What is your most comfortable cadence. Pick a gear that fits both.
Quoted: 118 Post(s)
Flat city streets, depending on how many starts and stops and windiness of the city, all factors that impact the decision,... That said, I would recommend 46 OR 44 front and 16 rear.
The thing about 44 / 16 is you can get up and go quicker with slightly less effort. That to me is a key factor for city-flat riding. But if I wanted to go FAST and get a better work out I would opt for 46 / 16.
But if you WANT the BEST strength workout and SPEED in flat city riding THEN that changes things.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
It depends on which grease you use. Tacky greases create more drag and require lower gearing to overcome that.
Bicycle Repair Man !!!
Quoted: 2953 Post(s)
Liked 3,106 Times
![](https://static4.businessinsider.com/image/4dcd20aacadcbbe261230000/nfl-hall-of-famer-ronnie-lott-just-invested-in-an-enterprise-software-company.jpg)
![](https://images-na.ssl-images-amazon.com/images/I/81xsMtxsAqL._AC_UL320_SR260,320_.jpg)
