My brand new Brooks is... painful.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
It's been a week since I've started using my new B-17 narrow on my commuter bike. (I have very... very skinny sit bones.) Today I gave in, and had to ride one of my other bikes. The Brooks is literally PAINFUL to ride. I decided to try a Brooks because for the last 4 years I've ridden with a normal saddle with a gel saddle pad on it to prevent saddle sores on the 4 mile commute (too short to wear a chamois or real biking gear.) So I said "well, these saddles are supposed to be great, even without a chamois, so I'll give them a shot." Yes, the gel saddle pad PREVENTED saddle sores. I've done many experiments with and without the pad, without the pad I get saddle sores, with the pad I don't.
Is this normal? I've decided I'll give it a month riding it as much as I can possibly stand. But honestly, this is the least comfortable saddle I've ever ridden. Other saddles (even thin "hard" ones) aren't "painful" but they will give me saddle sores after a few days of riding without a chamois. (Say, on a commuter.) It's painful directly ON my sit bones. Nowhere else. It feels like I've trying to dig my sit bones into a granite countertop with all my weight on it.
It's not the positioning of the saddle, it's the stiffness. The saddle is tilted up more than normal saddles, like people typically do with brooks saddles. That's perfectly fine.
I debated trying to loosen the tension on the leather in the front, but it's already at the end of it's range (I can't make it any looser from how it was shipped to me.) How long do these things take to wear in?
The bike I'm riding it on has a very small saddle to bar drop (and it's a flat bar commuter).
I just don't know how much I can force myself to ride this bike. It's quite... miserable currently. I already applied the proofhide, so I'd imagine applying neatsfoot oil would be hard at this point.
Any advice?
Any advice?
incazzare.
If it's not for you, it's not for you--and they're not for everyone. That said, I find that leather saddles I love can be hellish when not adjusted quite right. You say it's not the adjustment, but it may be. It also may be that even though you have narrow sit bones, the B-17N might be too narrow and you might be better suited to a Professional. It's just pretty much impossible to diagnose from here...
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Liked 2,327 Times
How long is your commute?
When I purchased my Colnago, it came with a Flite TI. I thought a saddle was a saddle and rode it. I soon found that I could not be on it for more than 30 miles. I went back to my then 30 year old Brooks Pro. Don't know how long I can ride it.
When I moved to DC, I picked up a Pinarello with a Flute TI. I knew 12 miles was acceptable so left it on.
Now after almost 4300 miles on the Flite, it is fine for the commute. I have acquired a number of additional Brooks Pro's and a Swift. I don't know about the swift yet but the others work just fine for my back side.
There are two break ins that need to occur to get to a comfort level, the saddle and the other part that sits on it. It takes time depending on what you were acclimated to. Some say a Pro needs 300 miles to be broken in. I don't know what the B17 needs. My understanding is that since the leather is thinner, less miles.
Bottom line, so to speak, if it isn't working after this time period, I question if it will work at all.
Takes around 500 miles to break in. They can be a little uncomfortable at first, but once they are broke in they are pretty nice. But every butt is different, I'd give it a little more time.
Semper fi
Semper fi
multimodal commuter
Liked 578 Times
Sorry to hear about your discomfort!
I suspect it's a matter of riding style to some degree; there is so little comparison between a gel saddle and a hard leather saddle that I don't think one really sits on them quite the same way. I'm putting this badly. Maybe someone more articulate than I will try to explain.
If you want to try extreme measures, here's what you do. 1, make the saddle wet. How wet, that's debatable. Some people put a wet washcloth over it for a few hours; others dunk it into water for a minute or less, then let it sit for an hour or three. Don't make it sopping wet, just let it soak up some water. Let the water soak in, so it doesn't look wet. This will soften it temporarily. 2, go for a short ride. Just enough that you can see the shape of the saddle starting to change. As soon as you see any change, stop. 3, let it dry. Give it a day or two.
After you've done that, reassess the situation. The process described will adjust the saddle to your anatomy. You can repeat it as many times as necessary, but it is hard to undo the changes, so I recommend taking it easy, give it a week or two between treatments.
Good luck!
Good luck!
If the B-17 N is too narrow for me... I'm not sure who it would be built for...
I'm also not sure how I could adjust it to make it more comfortable? Tilt it forward?
Liked 3,490 Times
my experience is that a B-17 works for me as long as I am pretty upright.
A b-17 narrow imperial (with the cut) did not work for me at all
The Swift works great and in road position with some drop from saddle to bar (not to much....to old for extreme )
in looking at saddles what I think makes the difference form is not just width, but have.... my old go to saddle that I still run on one my bikes was the orignal sella italia turbo. it has a bit of a rounded top at the back. The swift is similar, but the b17-narrow was way more flat
good luck
good luck
Life is too short not to ride the best bike you have, as much as you can.
Good luck!
Good luck!
I'll try to give it a month. If there is no change in comfort by the end of the month then I'll have to sell it or try something more drastic.
working on my sandal tan
Liked 2,600 Times
I'm of the mind that a saddle should at least be tolerable from the get-go. Yes, a brand-new Brooks is hard, but if adjusted correctly, it should be no worse than sitting on the corner of a wooden table. Severe pain and/or numbness haven't gone away with 300-1000 miles of break-in, in my experience.
Despite the nominally wider aft end, a Pro might be a better fit for your narrow sit bones, as the top shape is a little more rounded and the center section seems narrower than a B17N.
Or the Fizik Arione might just be better for your anatomy.
Liked 2,327 Times
Liked 644 Times
It might be too wide. You said you have very skinny sit bones, [MENTION=345109]corrado33[/MENTION]. Is your old gel saddle noticeably narrower?
I've been noticing my B17s and my B17-width RHM saddle are all seeming to wide for me, these days. Not enough to get rid of them, they just don't seem to disappear right away like the Pros and (gasp) Unicanitors do.
I'm with [MENTION=251447]ThermionicScott[/MENTION], a saddle should be at the very least tolerable from the get-go. This is assuming you're a regular rider who does significant miles. And also, that slightly rounded up section towards the back is pretty much a must-have for me. The B17s all seem to start fairly firm back there, then flatten out more than I'd like. Once I start to sink into them, it's not so good anymore.
If you get saddle sores from a 4-mile commute if you don't have padding, your physiology/anatomy is unique and likely requires something more specialized.
A couple ideas on accelerating the break-in on your Brooks here:
Breaking in a Leather Saddle (quickly) | Rando Richard
Don't throw in the towel yet on Brooks. I freaking hate the B17N I rode 10 miles on one and spent the last 5 pedaling out of the saddle cause it was so painful. However, my B17 is like butter and I can ride as far as my legs will handle on it.
You might also look into the Brooks Cambium models. I have a C17 and it's amazingly comfortable too, and weatherproof, so you don't have to worry about getting the saddle wet.
I'd try setting it level. An up nose position works for some people, but it will tend to put more pressure on your sit bones IME. It's a bit counterintuitive.
If you're actually getting saddle sores - as in red boils or welts, try some aloe vera. Old school but does wonders.
Bikes: 1980 Koga-Miyata Gentsluxe-S, 1998 Eddy Merckx Corsa 01, 1983 Tommasini Racing, 2012 Gulf Western CAAD10, 1980 Univega Gran Premio
Liked 11 Times
Thanks for the advice! I was hoping you'd comment. I'm not sure if I want to go the water route yet. The saddle is brand new, and if I don't like it, I'd like to be able to sell it while still claiming that it's as "good as new." I don't know if I could do that in good conscience after doing the water treatment.
Liked 2,600 Times
Let me know if you need to sell it along. I just did a longer ride (only 26 miles) on my new old B17, and while my sitz bones have never been better, I'm sore where the edge/side of the saddle pushed into my inner thigh. I figured I'd try a B17 narrow next, and then a Pro if that seems too narrow.
Bikes: Too many, but sometimes not enough.
Liked 18 Times
If your B17 narrow is painful now, I don't think it's going to get much better. Usually, a good fitting leather saddle will go from good, to great. Not horrible to good or great.
One last point - it seems Brooks changed the width and shape of the Pro some time in the 80s. I like the slightly narrower, more rounded earlier version. Modern production ones seem to flare too much at the back, with a flatter rear profile. They're ok for 20-30 miles, but not much more for me. The older ones fit me like a glove.
incazzare.
As far as adjustment, any direction may make a difference. Some people like leather saddles lower or higher than other saddles. Most (but not all) like the nose tilted a bit up, but the degree varies a lot. You may also find that you want it farther back or forward. This is all generic info, I know, but, again, tough to know what is going on from here.
But all that said, I also think I agree with ThermonicScott: if it's not at least ok at first, it probably isn't for you.
I'm not lying though. I know everything on the internet has to be taken with a grain of salt, but if I ride my 4 mile commute without the gel pad on top of my saddle, I will get saddle sores. Not after a day, maybe not even a couple days, but in about a week I will have uncomfortable saddle sores.
And I'm no slouch when riding either. I usually put in ~150 miles every week. My butt is perfectly accustomed to road bikes (and mountain bikes when ridden offroad), but when I'm out on the road bike I wear a chamois. When I'm commuting to work, I really don't want to. Plus I'm often on and off the bike throughout the day, so that would involve me changing multiple times per day and that gets really annoying.
+1 to this. I find my backside needs a more rounded saddle top. Brooks Pros, and Ideale 90s fit the bill, and are comfortable from the get go, even when very hard and stiff. I've tried a few Fujita belt saddles, which are closely patterned after the B17. They have a flatter rear section, and a sharper transition from the sides to the top. I dutifully put in a few hundred miles on them, to no avail. Always felt like my sitbones were sitting on a corner of the saddle, rather than supported by it. From looking at the relatively wider width of the Fujita, I think it was extending past the sit bones, and digging into the flesh just past them, with painful results.
I despise. I don't know why, I can't get comfortable on them. My bianchi came with one, so did my panasonic. I tried to ride both of them and I couldn't get comfortable on either. For me, they require almost mm precision on where your butt is forward and backward. If the saddle is too far forward it shoves me into the handlebars. Too far backward and I'm sitting on the "soft bits" between my legs. I move a lot when I ride, I shift my weight around, so having a saddle that requires me to sit in the EXACT same spot every time is... not ideal. I rode one of the curved saddles probably ~150 miles (5ish rides) before I decided to buy myself a flat saddle like the ones I typically ride.
Yeah, like I said, tough to diagnose from here. But it's not all about width in terms of the numbers, the shapes of the saddles are different too. If you want to try a thinner one, there are some vintage saddles that are smaller. RHM may have one or two that he has recovered?
I intended no doubts about your problem, and it does sure sound like you need a padded saddle of some sort or padded shorts. Or you might consider padded briefs, which you can wear under work clothes, but you'd still have the problem of needing to change in and out of them throughout the day.
Bike Butcher of Portland
Bikes: It's complicated.
Liked 6,174 Times
