Scuffed Brooks Professional
WGB
Bikes: Panasonic PT-4500, Miele Touring and Batavus Pro
Liked 2,489 Times
Brooks Professional (B75 stamp so assuming 1975). Has scuff to rear. Scuff is not fresh and has been there for years.
Seeking advice on covering scuff. Was thinking of a bit (small bit!) of brown Kiwi shoe polish daubed over the scuff and allowed to dry and then apply proof hide. Any thoughts.
PS Would that 75 be correct for date?
PPS The small white dots are fluff from teh rag that I noticed after I photo'd
Not horrible but not nice
Sorry for camera flash
If you can't call it patina and ignore it--the best solution for any cosmetic bike issues, in my opinion--take it to a cobbler and have the scuffed area dyed to match the rest of the saddle. I did that with a Belt saddle and was happy with the cost and the result. I don't always take my own advice about patina.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Saphir makes a rejuvenating cream that works well.
https://www.hangerproject.com/saphir...air-cream.html
Liked 644 Times
I have done it using the shoe polish method. Super easy, but required a half dozen applications to get the color all the way dark. And I didn't so much 'daub' it on as rub it in vigorously with lots of force. This was on a couple of black saddles, not brown, which may be harder to match exactly.
Liked 6,828 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,999 Times
WGB
Liked 2,489 Times
Thanks all!
I checked that website but at $11.40 at ube and three possible choices of brown, I'll start with Kiwi and see how that goes.
WGB
WGB
Liked 644 Times
But one could switch to black pants until one's saddle is completely buffed out, too. That's how I did the second one. Wintertime riding, I'm generally in black wool slacks anyway.
Extraordinary Magnitude
Liked 1,791 Times
I'd just leave it.
Commence to jigglin’ huh?!?!
I once tried to change a black B17 to brown... I failed.
What I was left with was an ugly bluish-black saddle that was mostly sanded down beyond the top finish.
I was able to bring it all back by applying Eco-Flo leather dye and buffing out with natural shoe polish.
It now looks better than when I first started the experiment.
multimodal commuter
Liked 578 Times
I have "fixed" blemishes of that kind with very light sanding, dry, with a very fine sandpaper, followed by gum tragacanth, and it worked pretty well. You apply the stuff, which doesnt smell real good, then burnish it to a sheen as it soaks in and disappears. But honestly I've only done that to learn how to use gum tragacanth, which I had already bought anyway. In the case of this Pro (and yes, 75 is the date the frame was made) I'd burnish it with Proofide or the like (I have a mixture of beeswax and neatsfoot oil), or shoe polish, or both.
@rhm, I thought Gum Tragacanth was a classmate of yours at the U of Chicago.
and Google leather slicking. It can also be done with water dampened leather.
If you are going to try dyeing the spot, you would need to strip the existing conditioners/treatments off first.
I would just dampen it and then slick/burnish the leather smooth then apply the preferred leather treatment. I use Proofide.
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Liked 210 Times
When my work wingtips used to get scuffed around the edges of the soles, I used a black permanent Sharpie marker. 2 coats on the edge lasted for a long time. I used the same on a vintage Ideal 39 saddle and never had any transfer.
Thrifty Bill
Liked 1,010 Times
+10 on small scuffs, black permant marker for the win. I tend to rub it with a rag while it is still wet to get it to blend in.
I was looking around for my copy of the NCO Handbook, which describes it. ... must have gotten rid of it, unfortunately.
My fuzzy memory thinks that it mentioned using smooth plastic too, such as a toothbrush handle. I know that I've done this for a Brooks Pro with reasonably good results.
I did try to find a reference to boning leather on the web, but keep coming up with a process to make a holster conform to a pistol.
Steve in Peoria
rideandgoseek
Classic and Vintage Sales
3
07-20-18 08:46 AM
Salamandrine
Classic & Vintage
13
06-11-18 12:01 PM
