Garmin Edge 810 DIY Battery Replacement?
climber has-been
Quoted: 3605 Post(s)
Liked 3,795 Times
It looks like the old battery in my trusty Garmin Edge 810 is not what it used to be.
I turned off Bluetooth and the back light, as Garmin suggests. On a 2-hour ride, it still lost 20% of its charge. At that rate, it won't make it through a long ride.
I'd rather not send it in to Garmin and be without the unit for who knows how long. Has anyone replaced a battery in a Garmin 800/810? It looks like a simple process.
I found this site that sells a 1000 mAh replacement battery and installation kit:
Batteryship.com - Garmin Edge 800 Battery Replacement
Replacement Battery for Garmin Edge 800/810
Randomhead
Liked 3,802 Times
I use an external battery on all of my long rides. I am pretty sure my battery life on the 800 is still good because of that. A lipstick battery will last about 20 hours. Something to consider
Likes For unterhausen:
climber has-been
Liked 3,795 Times
Do you need a special cable to keep the Garmin from going out of recording mode?
Quoted: 6387 Post(s)
Liked 4,982 Times
I wouldn't trust the battery meter. The voltage profile is what that is looking at and if your battery is slightly off that, then it'll have you thinking the battery is low when there is still plenty of capacity. Estimating battery capacity from voltage is only precise when everything is perfect, IMO.
Have you ever let it run longer?
Randomhead
Liked 3,802 Times
I think the special cables are only needed for the 500. I have never found a cable that wouldn't charge my 800. Of course, Garmin could screw anything up, so ymmv
My Edge 520 flips into "data" mode when connected to an outside power source. A cheap dongle fixes this. There are easy ways to disable the data link in a cable, too, so that you get power only.
Randomhead
Liked 3,802 Times
I have never heard of anyone having external power cable problems with an 8xx, just 5xx.
Quoted: 2650 Post(s)
Liked 2,006 Times
Likes For pdlamb:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
climber has-been
Liked 3,795 Times
While the 810 "worked" with the new battery, not having a working and waterproof on-off button rendered it useless. I ended up replacing it with a new 830.
Occam's Rotor
Liked 2,331 Times
Thanks. I just bought one for my 130. Then they sent an email saying not to expect it before March. Maybe I should quit while I am ahead (assuming they allow cancelling the order). (I can replace the 130 with a new one for as little as $150.)
Flounce
8
02-23-17 12:07 AM
TromboneAl
0
04-23-13 06:19 PM
ambient
11
06-22-11 05:59 AM
