Looking for inexpensive way to add a water bottle.....
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
I've been up and down on Google and Ebay, till my eyes crossed, and figured I'd better just consult The Matrix here.
I ride in a rural area, with water sources relatively few and far between, and with summer coming on, I'd like to add a small water bottle, either on the seat post, or more preferably, on the handle bar.
I found a inexpensive, decent-looking clamp on ebay, but it looked to be too small for my 31.8mm handlebars.
I figure there's gotta be some decent, cheap options out there, but I'm not seeing them. As always, any help, advice, warnings, points-in-the-right-direction,etc, are all much appreciated.....
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,452 Times
T/A bar mount with hose clamps instead of the supplied clips. Get creative.
WALSTIB
Likes For hillyman:
WALSTIB
Likes For hillyman:
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times
Not inexpensive but a stem caddy by Outer shell will hold 32 ounce bottles by Nalgene and others.
Again not inexpensive but Widefoot carries a lot of water.
Likes For Gconan:
Bikes: Trek Marlin 6 29r - Scattanti road bike w carbon fork - Trek 6500 - Univega Alpina 503 - Specialized Sworks M4 made in USA
Quoted: 90 Post(s)
Liked 103 Times
There is a handlebar-stem bag that serves as food/snack or water bottle bag. I just looked at mine on the bike and it is a no-name foil lined blue bag. I always have a water bottle in it . They are somewhat soft so I give the bottle a slight twist when I put the bottle back in. There is a drawstring top edge but I never use it. it is quite handy.
Likes For Olefeller77:
Mad bike riding scientist
Quoted: 6273 Post(s)
Liked 4,300 Times
The Minoura handlebar mount Is cheap (about $10) and effective. It fits diameters from 22mm to 35mm.
Stuart Black
Stuart Black
Likes For cyccommute:
Likes For coupster:
WALSTIB
I've got a similar design one permanently mounted just outboard of the stem. When I know that I'm going to need more water on a long ride I mount a cage and away I go - when I'm done I take the cage off. I've also got a B-RAD system from Wolf Tooth that converts a single tube mount to a double. But it ain't cheap like the HB mount. Still you can never have too much water.
Non omnino gravis
Axiom Oceanwave 1.3
Two things in one. I have an older Axiom bag of the same design. Gets used every summer.
Likes For DrIsotope:
Quoted: 1188 Post(s)
Liked 851 Times
This was the method of attaching a water bottle cage to the frame, either seat tube or cross tube, in the 60-70s. Even top of the line bikes used this method.
Water Bottle Mounts
Water Bottle Mounts
SE Wis
Quoted: 2755 Post(s)
Liked 3,422 Times
Likes For dedhed:
https://www.wiggle.co.uk/topeak-cage...SABEgLxwPD_BwE
Likes For Witterings:
Quoted: 4560 Post(s)
Liked 2,804 Times
Mylar water pouch. Besides my frame mounted bottles, on longer summer rides I'll freeze a small water pouch and tuck it into a jersey pocket. There are several types and sizes, refillable or one-time use, including some with long drinking straws. Better shaped for a jersey pocket and lighter than a water bottle when empty.
Likes For canklecat:
Quoted: 529 Post(s)
Liked 255 Times
Unless you are going for short rides, it is better to keep drinks out of sunlight. I have been using an old cardboard box, for drinks, than carrying them on the back rack.
Minoura dual bottle saddle mount
Just received minoura dual bottle cage saddle mount, https://www.amazon.com/dp/B001B13J1E..._KA.REbE5DG53B. Looks great in front of saddle bag
Likes For delacrue96:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
In your center jersey pocket?
Liked 4,300 Times
Stuart Black
Stuart Black
Quoted: 7115 Post(s)
Liked 11,275 Times
Jersey pocket.
Quoted: 833 Post(s)
Liked 1,976 Times
+1 on the Camelbak. Not popular among roadies but essential I believe in hot/humid zones. It encourages me to drink more instead of fiddling w/ a bottle.
I use one of these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I use one of these:
Likes For CAT7RDR:
WALSTIB
I'd use it all as an excuse to justify purchase of a touring bike with 3 water bottle cages. Might as well go Cadillac bike. The air smells sweeter, food tastes better and everyone waves hello
Quoted: 302 Post(s)
Liked 136 Times
You do know about this invention, don’t you?.......
And many thanks to everyone for the wide range of suggestions. To respond to some of them.....
-Thanks, but some if the suggestions are well beyond the "inexpensive" requirement I mentioned in the OP.
-Thanks, but some clamp suggestions won't work with the larger 31.8mm bar I mentioned in the OP.
-My jersey pockets are already loaded with stuff like keys, cell phone, spare tube, CO2 inflator,etc. so a water bottle would be pushing it.
-The larger cage that will hold big Nalgene bottles was a good idea (I have a bunch of Nalgenes, they show up often for .25-50 cents at the aforementioned thrift stores), but I'm using some pretty jumbo Euro bottles already, and don;t think the Nalgenes hold very much more, and probably not enough to justify the cost of expensive new cages).
-Right now, I'm leaning towards one of the inexpensive handlebar clamps on Ebay, and a member here has PM'd me links to a couple good options (and personally vouching for the quality of one of them). These seem to be the most economical and unobtrusive options so far.
Anyway, thanks again to all for taking the time to weigh in, lots of good food for thought here........
Likes For rollagain:
Quoted: 1324 Post(s)
Liked 927 Times
On my touring bike I put a water bottle cage on each front fork leg.
Cheers
Cheers
Likes For Miele Man:
