Cleaning rims for braking -- when, how and how often?
Bikes: Gary Fisher Advance (1993, heavily modded); Fuji Absolute 2.0 (2010; modded); 1989 Miyata 512 (58cm; $50, thrift buy); KHS Classic (63cm, 12-spd); Schwinn World Sport (58cm); Schwinn Voyageur (58cm); 1987 Centurion Ironman (60cm); etc.
Liked 45 Times
I have center caliper brakes on my Gary Fisher, and use Kool-Stop Eagle 2 pads. All my riding is commuting/city here in LA county, Southern California.
I've heard various suggestions on when, how and how often to clean/maintain the rims. Everything from once a ride to "as needed".
How do I "litmus test" for a dirty rim? E.g., paper towel with 90% isop. alcohol, rubbed across the rim, and it turns black. I do this, and this is indeed what happens even though the rims look "clean" from a loose glance.
Also, what is the best/quickest cleaning method? Say, Scotch-brite with 90% isop. alcohol, etc.
Lastly, should I use non-petroleum chrome/metal polish (e.g. car buffing compound; Bass polish) to keep the rims smooth?
Thx!
Thx!
aka Phil Jungels
I just clean mine with alcohol, after washing the bike (just a wipe with an alcohol wetted cloth) - about every month or so! If I do a lot of miles, and am cleaning/oiling the chain, it may get an extra wipe!
Liked 45 Times
I should've asked earlier ... how much difference does a cleaning like that make in braking performance. A little, a lot, or enough to matter?
Liked 45 Times
Okay, I just cleaned both rims quite thoroughly. With towel and 90% alch. I also followed with Scotch-brite scrub and toweled/alcohol'd again.
It made almost NO difference.
On a related note, front braking (despite having brand new pads) are the problematic ones of the two.
The rear pads are nearly 10 years old (but still have ample tread) -- but rear braking is decent on this Fisher.
IIRC, front braking used be much more effective (i.e., "grabby")
(BTW: The cables were replaced concurrently on both front and rear, and are in good shape I think)
Any suggestions for better pads, mounting / aligning techniques, resurfacing rims, etc. are appreciated.
On Your Left
Liked 2,434 Times
Aluminum or carbon wheels?
I have Zipps and they recommend acetone.... it works great.
Liked 458 Times
Thx!
Thx!
Liked 45 Times
Acetone? Really? You/Zipp must be thinking of use with tires removed.
From Google: "Acetone will not dissolve rubber, but prolonged exposure will degrade it. "
Or as a last resort, there is always 1,1,1-trichloroetheyne. It'll clean up anything.... But it might give you cancer.
On Your Left
Liked 2,434 Times
I keep all the socks (so many!) that develop holes in the heels for rags. I usually hold a plain dry rag up to the braking surface and walk the bike backwards one rotation. If they are really nasty, I'll do it twice each side. Depending on the weather, I usually do this procedure once a week. I also will release the calipers (canti) and manually wire brush the surfaces of the pads if the weather has been lousy (i.e. wet or sloppy).
Likes For prairiepedaler:
Liked 2,008 Times
I'll wipe down the rims with a clean, dry (to start with!) paper towel after a rainy commute, if it's not also too cold. Hard for OP to relate, from LA, I suppose.
I'll also wash the rims when I wash the bike, 3-4 times a year.
Difference? Fewer squeaks and less grinding noise if there's enough black to see a difference after cleaning. Haven't seen any change in brake effectiveness, except for the back wheel the time or two I over-oiled the chain.
aka Phil Jungels
Yep, don't forget the pads!
Liked 1,987 Times
I just use a damp cloth or Lysol wipes. Seems to work well removing dirt and not causing discoloration. I also clean the rims and spokes with Lysol wipes after every ride as a way to check spoke tension while cleaning. Occasionally I'll find a loose spoke.
Getting grit out of the pads is a good idea. That tends to be more of an issue on my winter bike. I usually hear it if it's there.
Otherwise, I'm probably like most cyclists, in that I clean things more often than necessary, and not for any functional reason.
Liked 45 Times
Actually, now that I think about it, I do clean the rims about 1-2x week, usually with a clean, dry towel. But every other week with Windex. I do this mostly for cosmetics-- i.e.,spokes, wheels, but the braking-rim surface does get some love in this ritual.
Still, with my recent deliberate cleaning of rim (brake-pad mating area), I did pull off black stuff. May've been partly the 90% alch. towel rubbing the tire???
On Your Left
Liked 2,434 Times
BTW.. i clean my wheels at the same time I clean the bike... about once a week or 150 miles.
Liked 45 Times
The following image is from Sept. 2004. I'm still using the SAME bike, calipers, brake pads (!!), rims/wheels, tires, maybe 12k miles later (only changed brake cable once)...
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/400x358/brake_pad_40055652b174a2e4da45f3b8d84283d6b700dbc2.jpg)
I think that toe-in geometry on the Kool-Stop Eagle "Claw" is correct?
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Liked 144 Times
Once in a while, maybe every 200 miles or so. I use degreaser on a paper towel, with bike on work-stand. Hold moistened towel against rim, careful not to contact tire, and spin wheel by hand. Turn towel to put clean surface on rim, and repeat until no more clean, moist surfaces left on towel. Done!
working on my sandal tan
Liked 2,579 Times
SE Wis
Liked 3,428 Times
Every time I ride in the wet/rain I hose the rims off when I finish. The black, oily, gritty runoff is amazing. Then I use brake clean on a paper towel when they have dried.
I'll usually also clean them with brake cleaner when I clean the chain or when I do a general cleaning.
Likes For dedhed:
Zip tie Karen
Liked 1,543 Times
My commuter bike has disc brakes, so...unrelated to this thread.
But for my other bikes, it's whenever I feel like it. For example, if I have the bike up on the stand for a chain measurement or lube and wipe, then I am also likely to give the rims a wipe also. I use the ammonia-based spray "Dirtex" as an all-purpose cleaner. Spin the wheel and spray. Wipe with clean cloth. Walk around to the other side of the bike, spin and spray. Wipe. This keeps most rims acceptably clean.
But my bikes aren't immaculate. They're clean and work very, very well. But they're not showroom clean.
The toe-in looks like it could be a litle excessive, but not bad. I'm a little curious about the anlgle of your straddle cable and the poisition of your brake arms. Could you post a head-on picture of your brakes?
Liked 4,081 Times
Unless you get oil on your rims, there is little you 'have" to do except road grit is destructive to the braking surface. When I hose my bikes off post-ride with a light spray, I blast through the rim and brake pad with the jet. I wipe my rims periodically, mostly for appearance, with either a clean rag (old socks and T-shirts like above) or paper towel but rarely has this been to cure a problem or have I noticed a change in braking from those wipes. I don't see the black braking dust as a braking problem, just appearance, Now the road grit, especially the local northwest volcanic grit can be very destructive and is the biggest limiting factor on how long my rims last.
Ben
Ben
