Chain worn out
Bikes: yes, i have one
Quoted: 1152 Post(s)
Liked 1,195 Times
Chain worn out
My chain has worn out. normally i would have this done at an LBS but i like to learn how to be self sufficient. Other than chain, what else do i need to make the swap myself? my ride is an 8 speed with a shimano cassette on a trainer and an sram on the ride. current chain behaves well on both. I have heard that i should replace like chain with like.
other than chain, how about tools? i do have a chain removal tool that i have never used before and some funky looking pins in the kit (all 20+ years old). i've heard about power lock, speed lock, speed link, quick link...
shimano, kmc, and sram chains...
Quoted: 6346 Post(s)
Liked 4,948 Times
If your current chain behaves well then what do you base it being worn out on?
Some of the chain checker tools can be hard to use or easy to misunderstand how to use them. There are also some common ones that for some types of wear will indicate a bad chain when it's really not bad.
Liked 1,195 Times
Liked 4,948 Times
Short? You mean longer don't you?
Bikes: Canyon Endurace
Quoted: 1052 Post(s)
Liked 934 Times
If your current chain does not have some sort of quick link you'll need your chain tool to pop a rivet on the old chain in order to take it off. When you size the new chain you may need that tool again to remove a link or two before you insert the quick link. That's about it. They do sell quick link tools that make installing and removing a little easier, but they're not usually required.
Quoted: 1439 Post(s)
Liked 1,094 Times
Of you have let your chain become that worn you may find that the new chain will skip on the also-worn cassette. Hopefully your chainrings will not be worn as well.
Liked 4,948 Times
If you measured it with a ruler......... then good. Although it might still work well, if it is that strectched, you probably should replace it. That much and it's likely already worn on the rear and front gears.
However, I'm always in favor of try it and see. You'll know soon if it begins to not run correctly if you need to replace the front, rear or both. If the instructions in your chain tool box aren't enough, I'd go to youtube and search for changing a tire chain. The youtube vids made by Park Tool are usually pretty good so watch those. And any that are from actual chain mfrs should be good too. Others, might give you some other insights, even if it's that they botch it up because they are just making vids without adequate skill or knowledge.
Your chain tool kit might have various size pins for different size chains. So make sure you get the right pin. Might be a sizing diagram on the instructions. Same for quick links or their equivalent.
Replacement chains from KMC and Shimano in the 10 and 11 sizes usually come with a quick link or at least a pin. Don't know for certain how well they do this for chains for smaller cassettes and freewheels as I've not used one in a very long time.
If you bought the same cheap chain breaker tool I did, then it might break the first use. So be ready for that. I still just use a small punch and hammer with a heavy piece of steel with a small hole as a backer to get my chains apart. But I'm very old school on that and it does take some finesse developed over years to hold it all properly.
Size your new chain to the old chain. If you have issue shifting it might just be slight tweaks of the adjustment screws, not the limit screws. However if the chain doesn't stay on cogs or rings. Or it skips on the cogs or rings, then you might need to replace them too.
Some replace them anytime they replace a chain. And that's fine if you are a high mileage rider and go through a chain every year. Or it just make you feel good to have done so. I just believe that most preventative maintenance cost more than wait till it breaks. And why stop at cassettes and chain rings. Shoot just replace the whole bike every time you need a chain. <grin> But while I poke fun at some that claim you must replace cogs too, you just have to decide for yourself what works for you.
Really Old Senior Member
It gives 3X the resolution.
I use the 1" & 37" marks to avoid errors introduced by the hook.
Likes For Bill Kapaun:
Quoted: 114 Post(s)
Liked 120 Times
...I have heard that i should replace like chain with like.
Personally, I like the SRAM chains for 8 & 9 speed. These chains come with the Powerlink, which is a reusable masterlink you can disassemble and assemble with your fingers. It makes future chain maintenance easier. To disassemble a Shimano, you need to use the chain tool to drive out a pin, then to reconnect, you need to use the chain tool and drive in a new pin.
You can get a SRAM 8 speed chain: 830 chain for $9 / SRAM 850 for $12 or SRAM 870 for $16. Any will work, and are mechanically equivalent.
I view chains as a maintenance item. I replace roughly every 4,000 miles or so, when the measured stretch approaches 1/8". As others said, and elongated chain essentially reshapes the teeth on the cogs in the cassette, and thus when you install a new chain, it may jump/skip when you apply power. I try to replace before this damage occurs, but I do end up replacing the cassette for every two or three chains.
Good that you measured your chain as preventative maintenance and I hope you cassettes are still good.
worn out chain has worn out wherever it touches, too ,.. so you may have to replace cogs front and rear too,,
cassette & chainrings...
Liked 1,195 Times
Thanks all. new chain going on tomorrow. if trouble under power guess a new cassette is in store for me as well.
-scott
-scott
Replace the chain at 1/16" wear. Depending on how you clean the chain the smaller cogs should last through three or four chains.
https://www.sheldonbrown.com/brandt/chain-care.html
Likes For davidad:
Bikes: Soma San Marcos
Quoted: 7 Post(s)
Quoted: 7 Post(s)
For me, personally, I could not always rely on comparison to the old chain since worn chains might have stretch in them and can mislead you to break your chain too long. I have found more reliable success when you size the chain routed along your largest front chainring against your smallest back cog on the rear. Park Tools has awesome, in-depth yet clearly explained videos on YouTube to measure and size your chain. I'm sure your local bike shop won't mind taking a look at whether the teeth to your cassette or front chainrings are worn to see if the problem isn't just the chain.
Liked 4,948 Times
https://www.bikeradar.com/features/h...bicycle-chain/
https://www.velonews.com/gear/techni...r-measurement/
If you have not already spent money on a chain checker, then the tools that measure to the same side of the bushing will be more accurate. However, even the inaccurate tools are erring on the better side and will have you replacing your chain a little early as opposed to too late. So no harm done except you might have to budget a case or two less beer in your lifetime since chains are more important. <grin>
I still use the "inaccurate" chain checkers. I already had one before this was a known thing to me. They are still quick with the chain on the bike. A ruler will require me to get in a well lit area and position the bike where I can see the scale well. So I don't have to bring out a metal scale till the checkers start to show a problem.
Likes For Iride01:
SE Wis
Quoted: 2755 Post(s)
Liked 3,425 Times
You need a 6-7-8 speed chain from any reputable brand (preferably with a quick link), a chain tool, and time.
You'll usually need to shorten a new chain.
Plenty of youtube videos out there.
Remove old chain - quick link or push a pin out with chain tool.
Shorten chain to match old chain length with chain tool.
Install new chain feeding it through rear derailleur correctly and closing with quick link
Ride it and see if anything else is worn enough to not play nicely with the new chain. If it plays well together - Done
If it doesn't, you'll likely need to replace the cassette/freewheel which will require 1 more tool to remove/replace. Chainrings do not wear nearly as fast as rear cogs.
SE Wis
Liked 3,425 Times
Any wear is not going to add enough significant length to add up to breaking the new chain an extra link.
Likes For dedhed:
Liked 4,948 Times
Likes For Iride01:
Liked 1,195 Times
So replaced the chain today and used my chain tool that i bought over 20 years ago in preparation for a bike tour in the philippines but never took (got married instead, but that is another story).
holy cow! that was actually hard. i though i was doing something wrong but i finally got one of the pins out. shimano chain. seemed like it took forever, the tool really has no mechanical advantage, i had bought it for its compactness. anyway, chopped of a few links from the new chain, installed, and the ride was like night and day. shifted like as smooth as a baby's...and was the ride ever quiet. i really need to monitor that chain more frequently. even seemed to make me go faster*.
-scott
*absolutely no wind while out riding, average speed was about 3mph greater than usual. no wind is rare for reno.
-scott
Likes For krecik:
Quoted: 996 Post(s)
Liked 592 Times
This ^^. The chain-check tools serve as convenient "screening" tools... easy and fast to get a quick read on chain wear (and without getting fingers greasy). If excessive chain wear is indicated, then a "ruler" check can always be done. Since most chain-check tools seem to slightly over-estimate chain wear, the risk is that a chain with some remaining usable life will be discarded. I'd rather pitch a chain that I *could* get a little more life out of, than wear out my cassette or chainrings.
I think I know nothing.
Quoted: 233 Post(s)
Liked 290 Times
Likes For Thomas15:
No Motor Vehicles
My daily driver '80s Miyata has been shifting a little vague so I measured the chain today. I was expecting it to be 1/16" over, maybe a bit more. It's been a few months, it's probably time.
I was not expecting it be 1/4" over on 10" worth of links, and maybe even a hair worse, but that's where it is. Eeeep. I am apparently not good at preventative maintenance. (Yes, I oil it with Tri-flow and wipe it down periodically. No, I don't keep it shining spotless clean, who has time for that?)
Now should I order a new freewheel preemptively, or wait for the chain to come in and try it. Maybe it won't slip...
Liked 1,195 Times
