Cleaning Frame (Grease)?
Looking for advice on cleaning grease of the frame. I have spots on my frame that look to be grease from the chain and normal soap does not remove it. Anyone else have this trouble or any recommendation on how to remove it without using products that would damage the frame?
WD 40. Soap and water wash and then a little wax.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Likes For San Rensho:
Maguires Scratch X. Good for bike and car. A light rub does wonders. Follow up with Quick Detailer. Works for me.
https://www.amazon.com/Meguiars-G103.../dp/B0002UNON8
https://www.amazon.com/Meguiars-A333.../dp/B0009IQXAE
I learned this from a bicycle mechanic and it simply works wonders......Lemon Pledge!
Cheap and smells great to boot!
Licensed Bike Geek
Try Lemon Pledge. Works really well and your bike will smell good!
Bikes: 2022 Salsa Beargrease, 2020 Seven Evergreen, 2019 Honey Allroads Ti, 2018 Seven Redsky XX, 2017 Trek Boon 7, 2014 Trek 520, 2006 Gary Fisher Montare
Liked 937 Times
Zep foaming spray or Simple Green degreaser from your local home center works wonders.
Liked 1,651 Times
I use auto tire and wheel cleaner (make sure its the kind that is ok for painted wheels) on my drivetrain as well as on grease, tar, or other hard to clean gunk anywhere. Works really well so far and has had no adverse effect on paint or clearcoat.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Liked 355 Times
91% Isopropyl alcohol. 70% doesn't remove grease but 91% will, and will not damage paint, or leave a residue.
