Unconventional, Unorthodox, Irregular, and just plain insane? What have you seen?
There tends to be common themes you see amongst certain categories of bikes. For example touring bikes will have construction, components, and accessories that tend to lend themselves to comfortable long distance riding while loaded up. Road bikes often use space age materials and designs that reduce their weight for improved performance. Overall, there tends to be symmetry to some degree, and consistency towards a goal you want to achieve with a type of model bike and it's intended range or type of riding.
And then there are the bastards. Unconventional, unorthodox, inconsistent, irregular, and in some cases, insane? Things that might not make sense or lack symmetry, to stuff you wonder if the person was either insane or maybe a genius ahead of his or her time? Stuff that makes you question everything you've learned, seen, or been told about cycling. Franken bikes? A 2 stroke kit on a carbon bike? A CB radio mounted to a bike?
I'm curious what you have seen out there.....
Quoted: 1074 Post(s)
Liked 295 Times
Well, there was this guy with a DIY, weld-free SWB, FWD ’bent, where the owner/builder had forced a derailer gear rear wheel into a SUSPENSION fork, spreading it considerably. It was a 24” too.
Or the guy who’d lowered his handlebars by welding some iron strips from fork crown to a length of pipe clamped in the stem, then using pipe clamps to hold his bar to the iron strips running vertical from old bar position to fork crown. And it was a quill stem w/o removeable face plate.
Mostly though what irritates and amazes me are those who build expensive,(illegally) high powered ebikes based on department store bikes hardly fit even for human power output. And as if to add insult to injury, many of them simply unhook the front brake entirely.
Quoted: 431 Post(s)
Liked 719 Times
Nothing too unusual. But I used to live near the NCR (now called York Heritage) rail-trail. Liked riding by the Emu "farm" on the PA side. Also the gnome display on the MD side.
Quoted: 833 Post(s)
Liked 1,976 Times
I came across a group of lowered chopper style adult sized bikes on the local MUP. Just cruising around 10 mph. Very cool IMO.
Quoted: 18557 Post(s)
Liked 15,961 Times
Quoted: 3352 Post(s)
Liked 1,056 Times
I have posted about it many times, but what I find insane is the number of cyclist that are suckered into ever increasing number of gears on a bike. And too the insane prices of CF (plastic) bikes. Those bike will NEVER last like a metal bike. The plastic gasses of in time and becomes very brittle. There are Wright Bros steel bikes around, and with new tires would work just fine. I would willing to bet that if one of todays CF bike if kept around would be so brittle in 100 years a good thump would break a big hole in it.
Likes For Doc_Wui:
Likes For woodcraft:
Quoted: 4015 Post(s)
Liked 7,524 Times
P.S. Yawn.
Likes For tomato coupe:
Quoted: 4227 Post(s)
Liked 2,491 Times
That is a pretty good description of recumbents.
Likes For wolfchild:
Liked 15,961 Times
Likes For indyfabz:
Likes For JanMM:
Quoted: 915 Post(s)
Liked 2,100 Times
Likes For downtube42:
Quoted: 915 Post(s)
Liked 2,100 Times
The Alt Bike Culture subforum is pretty quiet, but that's were we post our creations.
Clark W. Griswold
Quoted: 4488 Post(s)
Liked 4,160 Times
A whole thread on something pretty crazy: https://www.bikeforums.net/alt-bike-...ar-newfix.html
Veteran, Pacifist
Quoted: 3925 Post(s)
Liked 4,912 Times
nahbs
Likes For Wildwood:
Clark W. Griswold
Liked 4,160 Times
Veteran, Pacifist
Liked 4,912 Times
Jon will build it, if you come.
Likes For Wildwood:
Expired Member
Quoted: 3782 Post(s)
Liked 5,768 Times
You don't have to go far to find "just plain insane." Several proudly posted right here on BF....
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2137 Post(s)
Liked 1,652 Times
Kinda related. I was cycling down our local MUP a few weeks back. In the distance was a runner/jogger coming at me at a very good clip. Smoking a cigarette as he ran.
Likes For Paul Barnard:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
there's a subred_dit page called "just riding along" that is a steady stream of weird stuff.
a friend of mine who works in a shop privately shares the weird stuff he sees every day, but it's best to not share those publicly. in short: some riders should not be working on their own bikes without supervision.
for some wild bikes that look unconventional but probably function wonderfully, check out:
Quoted: 581 Post(s)
Liked 921 Times
Partner and I used to play a game called 'Trash Factor' where we sat near a busy bike path and looked for cyclists with ridiculous clothes and accessories.
High points were given to people smoking while riding or with a deck of smokes under their t-shirt sleeve, large radios haphazardly taped to the handlebars, and expensive bikes paired with a $14 helmet from Walmart, among others
Likes For ClydeClydeson:
Sunshine
Quoted: 11061 Post(s)
Liked 7,622 Times
If someone is looking to ride a bike for the next 10 decades, then sure- maybe they shouldnt choose CF. For the other 100% of cyclists though, that isnt a concern so your point sucks.
