Stabilizing Bar Tape Plugs
senior member
My plugs have been wiggling loose after awhile - just wondering if others have ideas for keeping them in place - I thought about double sided tape or building up the plug diameter with tape to keep it in there tight - any other thoughts from the group ??
Quoted: 20810 Post(s)
Liked 9,456 Times
Ah, don't worry about it. If you're on a ride and notice that they're wiggling out, you don't even need to stop - just bang 'em back in the palm of your hand.
j/k - do *not* do that.
Seriously though, I can't say that I've had them work loose frequently enough for it to be even remotely problematic. The next time you re-tape, maybe another half-loop around the bar end would tighten things up enough?
Likes For WhyFi:
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
https://www.amazon.com/Supacaz-Star-.../dp/B01CCVUZYU
Use an allen key/wrench to tighten them in. Been using these for about 4 years...they never come loose.
If you get the oil slick colored ones it saves you about 3 watts PER bar end plug.
Likes For aplcr0331:
climber has-been
Quoted: 3586 Post(s)
Liked 3,771 Times
Likes For terrymorse:
Advocatus Diaboli
Quoted: 4805 Post(s)
Liked 1,547 Times
Quoted: 1533 Post(s)
Liked 725 Times
I usually only get this problem if the tangs inside the plug are cracked.
I also usually wrap top-down, so the plugs are doing the job of finishing tape.
Method to My Madness
Quoted: 2068 Post(s)
Liked 1,562 Times
Quoted: 550 Post(s)
Liked 326 Times
Nitto plugs which clamp in place.
Thread Killer
Quoted: 3239 Post(s)
Liked 1,798 Times
Kustom Kaps offer just the plugs, which can be spec’d in custom color combos.
Quoted: 18883 Post(s)
Liked 10,646 Times
The Enve ones when really well. I don't know if you can get them without bars, I assume they'll fit regular ones too if you can.
Quoted: 645 Post(s)
Liked 797 Times
which works OK, but Elmers is a cleaner fix IMO.
I don’t tuck excess tape into the bar ends - I start the wrap overlapping the bar ends then trim the tape flush with a razor - then install the plugs
senior member
Expired Member
Quoted: 3800 Post(s)
Liked 5,800 Times
OVERLAPPING....
Liked 3,134 Times
wine bottle corks.
-Oh Hey!
-Oh Hey!
Likes For Troul:
senior member
Expired Member
Liked 5,800 Times
YOU WERE ON TO IT IN POST #1, THEN FURTHER EXPLAINED IN POST #4. WRAP'EM AND JAM'EM. IT LEAVES A CLEAN END, NO BULGE. OR GET THE EXPANDING TYPE. OR WINE CORKS.
Likes For shelbyfv:
Sunshine
Quoted: 11090 Post(s)
Liked 7,681 Times
Just overlap the tape by half its width at the bar ends. Once you are done wrapping, jam the bar end plug in. There is no reason to go rogue on something as basic as wrapping bars.
If you want a better way, use any of the many suggested bar end plugs that have an expanding wedge.
I have these on all my drop bar bikes, for example- https://kustomcaps.com/products/sugar-skull-beps
The expanding rubber holds them in place and the only way to remove them is to undo the expansion before pulling.
senior member
Likes For blinky:
Quoted: 243 Post(s)
Liked 234 Times
Bar-end plugs for those with a Campagnolo fetish
senior member
senior member
Expired Member
Liked 5,800 Times
Just bought a pair of their BEPs and I don't think they expand at all - it's basically a machine screw that goes through a decorative cap and a rubber cork and then a simple threaded washer that holds it all together - don't see what would make the cork expand - the rubber cork is fairly fat and I think just a tight fit holds it in there .
