Top quality mechanical disc brakes short list
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I recently added a basic adventure bike with a 2x10-Speed Shimano Tiagra groupset and Lyra mechanical disc brakes from Tektro. While I wanted mechanical disc brakes to help simplify set-up and maintenance, the reviews on the Tektro Lyra brakes are consistently negative. What replacement flat mount mechanical calipers would you recommend? I'm researching Paul Klampers and TRP HY/RD but will consider other advanced alternatives.
Expired Member
Quoted: 3787 Post(s)
Liked 5,780 Times
AFAIK the TRP Spyre is considered to be the best functioning purely mechanical brake. You might research how it differs from the Lyra.
I think the Spyre features better pad clearance adjustment than most others.
Guest
Quoted: 1346 Post(s)
Liked 3,271 Times
Paul's are beyond my reach, but they and Spyre are the only ones worth considering, IMO.
Quoted: 910 Post(s)
Liked 288 Times
Spyre are a dual piston mechanical, and this is a key advantage. Most mechanical calipers are a single piston pushing against one pad. The other pad makes contact with the disc only after the piston presses the disc between the two pads.
The HY/RD's are super simple to setup and maintain, and they work almost as well as fully hydraulic brakes with compressionless housing and cables in good order. The only problem with them really is that if you ride a ton of miles and / or frequently in poor weather, the cost of replacing good quality housing more frequently negates the cost savings compared to full hydraulic. They will, however, still be much easier to setup and adjust for people that are only familiar with cable brakes.
Likes For zen_:
I'm running Juin Tech R1 on my Fog Cutter and they have been trouble free for over 4000 miles. I like the easier lever pull from the tops vs a full mechanical like the BB7, sort of in the middle of mechanical and full hydro. I don't have any experience with the Spyre.
I recently put on a set of Paul Klampers on my mountain bike, but don't have enough riding time to give an opinion.
Likes For katsup:
Quoted: 716 Post(s)
Liked 807 Times
Tektro MD-C550 is the OEM version of the TRP Spyre brake. They can be found for a significantly lower price than the Spyres and they are functionally the same brake. The only difference I can find, besides cosmetic appearance, is that they use a cotter pin to retain the pads and the Spyres use a bolt. I got the pair of calipers with rotors for around $100 on eBay. They are the best mechanical disc brakes that I have used.
Likes For dsaul:
Thread Killer
Quoted: 3226 Post(s)
Liked 1,774 Times
Yeah, Juin Tech GT get good reviews, as do the Yokozuna Ultimo.
I have to say, though, that I rode Avid BB7 for 15 years and was not dissatisfied with them. I think the BB7 variants often get overlooked because they were one of the first, but depending on what you need and want, are still good options.
Quoted: 910 Post(s)
Liked 288 Times
Quoted: 4227 Post(s)
Liked 2,491 Times
BB7s are the original and the best, everything else is just trying to re-invent a wheel.
Guest
Liked 3,271 Times
Evidently, Avid designed the BB7 to do two things: make noise and require daily adjustment. The only good thing I can say about them is that they're better than BB5s. I'd rather run cantis than either one.
Likes For Rolla:
I've used BB7s, Spyres, and Klampers. Klampers are hands down the best of the bunch. I was skeptical because of the price, but man they feel great. For drop bar disc I'd rate brakes in this order: Shimano hydro > Paul Klampers > Sram hydro > everything else I've tried.
Likes For niknak:
Quoted: 716 Post(s)
Liked 807 Times
I used the supplied pads for a while, but I really like the Kevlar pads from DiscoBrakes. so I switched to them. The supplied pads are good and I didn't have any issues with them, but the Kevlar pads stop a bit better and make it feel more like a Hydraulic brake.
Quoted: 7123 Post(s)
Liked 11,286 Times
Quoted: 338 Post(s)
Liked 408 Times
Use BB7 on gravel bike and TRP Spyre (flat mount) on road bike at the moment.
Both work, but prefer TRP Spyres which I really like. I've upgraded the group from 105 to Dura-ace but didn't feel like changing the brakes to hydraulic (will do electronic+hydraulic for next bike). Running XT 160mm rotors on both.
The TRP Spyres you won't regret.
Likes For Branko D:
Firm but gentle
I had good luck with BB-7s and the Tektro equivalent, I highly recommend compression-less housing. But eventually you will want hydraulic, unless it interferes with air/train/ground travel.
Likes For venturi95:
Thread Killer
Liked 1,774 Times
I’ve never ridden Spyres, but the hooded upper/pad bolt area seems like something nice for gravel riding, keeping mud from piling up directly atop the pads and pistons. Maybe a small thing, but a nice, quality touch, IMO.
I’ve got some BB5s on my road bike that gets pretty light usage so they are adequate. Not crazy about the gap you have to run in order to prevent drag and the resultant slack in brake contact so the other day I bought a set of TRP hy-roads for a good price. They seem like a very well made piece but god they are heavy. I’m not a weight weenie per se, but I don’t really want to bolt those things on too badly.
Quoted: 910 Post(s)
Liked 288 Times
Yes, full hydraulic has real benefits, especially lever effort and feel. I have two bikes with Shimano hydraulic shifters and brakes. I wanted this bike to have mechanical brakes. I will transport this bike on planes and trains. It will be used on tours and I won't have tools or brake fluid with me.
I have BB7, dont have much problems with them, actually I dont have to adjust them often, maybe once a month I fiddle with dials and not because they are off or not breaking I but I ride mostly flat roads. Having said that, yesterday ordered Juin Tech R1, lets see in couple of weeks if they will be better.
Thread Killer
Liked 1,774 Times
What do you mean? It does cover the top opening of the caliper, so it seems like it would impede ingress of water and particulates, which should be a good thing since I don’t believe the Spyres have any seals for the balls/cam/piston which moves the pad.
If you’re saying that’s a non-issue, well perhaps; I don’t know because I have no experience with them, but I took apart one of my BB7 once— just once was enough! There are lot of bits in those things!— and they have outer and inner seals on the piston side which may have been a factor in why I never had to rebuild them in the 16 years I ran them. I mean I did the one, but mostly out of curiosity, not because the action was gritchy or grindy.
Quoted: 1873 Post(s)
Liked 693 Times
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Thread Killer
Liked 1,774 Times
I guess what I'm saying is, yeah maybe they keep some stuff out but if conditions are bad enough (like Mid South), then in the end it doesn't matter, they'll get messed up. Also, the covers fall off easily. Also, they don't cover the "arms" and like you said those are hard to clean out. I have a set that don't retract fully because the arm pivots are compromised with sand and grit.
