Latex tubes, Carbon Clinchers and Rim Brakes
I'm thinking about trying out some latex tubes, but have read some info about them blowing if used with carbon wheels and rim brakes due to heat build up from braking, I live in a relatively hilly area. Anyone on here use latex tubes with rim brakes without issues or is this a def no no?
Thanks
Thanks
Should Be More Popular
Quoted: 22702 Post(s)
Liked 9,060 Times
I would only be concerned if you have really long descents (like several miles). I run them with zero worries, but our hills are typically a mile or less. I did worry a little when I went to ride Whiteface (8 miles at 8%) so swapped out for my aluminum wheels for that ride.
Likes For datlas:
Mother Nature's Son
Quoted: 860 Post(s)
Liked 1,453 Times
l use latex tubes most of the time. I do not have carbon wheels and live in a flat area, so, cannot comment from experience on those subjects. I think for heat build up to cause tube failure, it takes a fairly long, steep descent with a lot of lengthy, hard braking. I use latex because I find the ride to be enough improved to validate the extra dollars. I can usually find them on sale for less than $14, PBK has some now for 10.99 usd. The first few times you mount them, take your time and use extra care to insure proper installation, pausing to inspect the bead while inflating. Patching is no different than with butyl tubes, IME. They will sometimes stretch to the point it makes it more difficult to situate the tube in the tire/wheel without a bit of folding/wrinkling of the tube, which makes a pinch flat more likely.
I have done the same rough stretch of road, on the same bike and tires/wheels, same pace, with both butyl and latex tubes. IMO, the ride with the latex is considerably smoother, I suspect they might spin up just a bit quicker, but not enough for me to notice or care. I do not get many flats and usually just use another tube while on the road, then do patching at home. I have used Rema and a couple different brands of glue less patches, they have worked well.
Likes For delbiker1:
Don't ride the brakes. Both brakes at once hard, cool down and rinse/repeat.
Likes For popeye:
climber has-been
Quoted: 3545 Post(s)
Liked 3,696 Times
I have been using rim-braking carbon wheels with latex tubes for at least 8 years now, and it is quite mountainous here in the SF Bay Area. I've never had a tube fail due to overheating.
The "don't use latex tubes with rim brakes" warning is overly cautious, in my opinion. Tubular tires, the choice for professional cyclists for decades, use latex tubes.
Likes For terrymorse:
Quoted: 429 Post(s)
Liked 729 Times
How about some TPU tubes? Pricey but you drop a lot of rolling weight. I personally like them a lot (have used Pirelli and Tubolito)...
https://www.bicyclerollingresistance...bes#conclusion
Thanks all, was concerned as some of the descents where I live are up to 21%, will give the Vittoria latex tubes a try will need to get some valve extenders too as I haven't seen any latex tubes with a 60 or 80mm valve.
Advocatus Diaboli
Quoted: 4765 Post(s)
Liked 1,543 Times
But isn't the latex surrounded and buffered 360 degrees by the casing in a tubular, vs in direct contact with the rim material?
climber has-been
Liked 3,696 Times
Also, when the rim transfers heat to the tube, it quickly gets transferred to the air inside the tube, eliminating any hot spots in the tube.
The real world failure mode from friction heating of a tube is the increased pressure of the air in the tube. Enough heating can cause the pressure to exceed the tire's rating.
climber has-been
Liked 3,696 Times
Michelin makes a latex tube with 60mm valve stems. I have them, and they work fine, but they don't have removable valve cores (so no using them with sealant).
They're a bit smaller in diameter than the Vittorias, but that doesn't seem to affect how they hold up. If anything, it makes them a bit easier to install.
Michelin A1 Aircomp Latex Tube, 700x22/23 60mm valve stem
Liked 9,060 Times
Likes For datlas:
Quoted: 2333 Post(s)
Liked 2,097 Times
I've used carbon, latex, and rim brakes for around 8 years. Make sure you tape the spoke holes very well and be extra careful when mounting the tire, latex tubes are easier to pinch between the rim and tire but if you do that, the bang is usually immediate. The resin is also an important consideration, probably the most important if using rim braked
Likes For GhostRider62:
climber has-been
Liked 3,696 Times
got the climbing bug
Bikes: one for everything
Quoted: 635 Post(s)
Liked 929 Times
I'd be getting 75-80mm tubes plus some spare. I use these but not latex https://www.bikebling.com/Continenta...i-c1502227.htm
You may have to use valve extenders, which are PITA to use when you have a flat.
Rule #10 // It never gets easier, you just go faster.
Liked 9,060 Times
I have Reynolds Assaults that are 46mm and the 60mm valves are long enough. The extra few mm you would lose might be a problem but you could try. It may also depend on your pump head, I use the Hirame (best pump head EVER!) with plenty of extra room on it.
