Fender size?
Fender size?
hi,
could you you help me with right size fender for my bike, the tire size is 700x38c ?
thank you
thank you
Old fart
Quoted: 3620 Post(s)
Liked 3,460 Times
Measure the distance between the seat stays at the brake bridge and the distance between the fork blades at the fork crown, and that will tell you the widest fender you can fit. There's really no downside to getting a wider fender than strictly necessary, and too narrow a fender will not be effective.
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 48 Post(s)
Liked 43 Times
Take a look here, Bike Fenders - Front & Rear Bicycle Fenders - Planet Bike some pretty good info
Likes For bktourer1:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1317 Post(s)
Liked 763 Times
To sum up... in your case, Frame size and Capacity matters, not tire width... and i've seen some creative trimming done to fit too-wide fenders into a frame.
Likes For maddog34:
Quoted: 574 Post(s)
Liked 517 Times
That depends on the tyre and where it's used - with a smooth tread on a clean surface most of the water is flung off the centre portion of the tread so a mudguard that doesn't cover the full width is still quite effective.
Old fart
Liked 3,460 Times
Likes For JohnDThompson:
