Spray-on cleaner for shifters
I'm replacing my Shimano Ultegra rubber brake hoods, and prior to their arrival: While I have them off, (planning on leaving the shifters in place on the handlebars), with the shifter mechanism exposed, is there a once-and-done cleaner that will work to get any grime off of them, and lubricate at the same time? I've seen recommendations for WD-40 then a soak in mineral oil - for when you have them pulled and are able to place them in a small receptacle - I just do not plan on getting that involved with them.
climber has-been
Liked 4,058 Times
I just turn the bike upside down and spray ample amounts of WD-40 into the mechanism, working the shifter up and down the gears several times.
After everything dries completely, I might put a couple drops of oil on the moving parts. Or not. Those shifters don't seem to need much lubrication.
Likes For terrymorse:
Liked 676 Times
No need to pull, search on YouTube for "shimano STI shifter" and dozens of how to video's come up, many from quality shops doing it slightly differently and they all work.
Liked 3,680 Times
whatever vids I've seen, the presenter sprays w/ WD40
WD40 can be had with silicone. https://www.amazon.com/WD-40-Special...00&sr=8-2&th=1
Bikes: Trek CheckPoint SL7 AXS, Trek Emonda ALR AXS, Trek FX 5 Sport
Liked 2,049 Times
I would look at using a brake cleaner, will leave no residue and dries pretty quickly, then you can drop a couple of drops of lubricant on the moving parts. I hate the residue that WD-40 leaves behind.
I sprayed my “creaky” bottom bracket and it went away after my LBS says that there was nothing wrong with my BB.
They sell the Lucas stuff in Oreillys, depending where you live.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Liked 1,458 Times
Liked 2,707 Times
we have a number of bikes with Shimano Rapidfire and Dual Control shifters that sat for years untouched - many for decades - WD-40 was the fix for all
we keep multiple cans of WD-40 in a few different locations around our house - that stuff is versatile
you know you are old when you can recall when WD-40 first began to appear
