Di2 Ghost shifting
Di2 Ghost shifting
I recently bought a road bike with Di2. I've has a recurring problem with ghost shifting. Occasionally, when I hit a bump my chain shifts. It usually happens on the rear, but has happened on the front twice. Front is little to big. Back is usually up to a larger cog. I'm going to verify it's not me accidentally hitting the shifters by doing a ride completely on the drops. But has anyone else experienced this?
Quoted: 317 Post(s)
Liked 685 Times
Never. I've had 10, 11, and 12-speed Di2 equipped bikes and none of them have ever missed a shift or ghost shifted, and they've required very little maintenance.
Sounds like whoever you bought it from did something very ham-fisted when setting up the Di2 or potentially crashed the bike. Maybe a bent derailleur hanger, or a chain that's too long. Ghost shifting little-to-big chainring is very strange though!
Actually, are you sure the Di2 is not set up to synchro shift?
Likes For tempocyclist:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1326 Post(s)
Liked 1,307 Times
Honestly sounds like some basic mechanical stuff.
1. Check the chain, chainring for wear.
2. Your rear derailleur hanger needs alignment. Just align it and/or check the alignment.
3. Your chain is most likely not sized correctly (too long) or there is too little chain tension. This is basic setup stuff.
Go through the basics. Odds are this will solve your issue. If not then it could be all sorts of things. crank that is able to move in or out, cassette has play for a myriad of reasons, etc. It's basic foundational stuff. Make sure it's all good.
As for Di2 - just works better so if you're having problems then its a basic foundation issue that has changed.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
I bought the bike brand new, no crashes and not in synchro mode. Had the shifters and derailer warranty replaced. I've considered the chain, but the mechanics don't think it's an issue. But I'll bring it up again.
Quoted: 6330 Post(s)
Liked 4,923 Times
Keep taking it to the shop or a shop that is a authorized dealer for that brand of bike. Eventually the reps from the regional level and possibly Shimano themselves will get involved. A bike that doesn't work correctly from the start needs someone higher up than the shop people looking at it if they are puzzled about the solution.
Don't be too keen on fixing it yourself. If you mess something up then you might be left empty handed on getting support from the shop, the bike brand and Shimano.
Welcome to BF.
Welcome to BF.
Likes For Iride01:
Method to My Madness
Quoted: 2046 Post(s)
Liked 1,542 Times
Does a Di2 derailleur still use a return spring like its mechanical counterpart, such that the motor or servo only moves the derailleur in one direction (to a physically larger gear) and the return spring moves it in the opposite direction? If yes, what the OP describes sure sounds like an electrical short in the system. (Pardon my ignorance, I do not (yet) have a Di2 bike.)
Thread Killer
Quoted: 3214 Post(s)
Liked 1,752 Times
Liked 4,923 Times
You do know that depending on what version of Di2 you have and the range of your rear cassette, Di2 won't go into the 12 and 11 cog when in the small chain ring. Regardless of what shift mode you are in, Di2 will make the appropriate shifts to keep you out of those combos.
Liked 4,923 Times
spelger
It only shifts when you push the buttons. However it might be more than one shift. If in manual shift mode and you are in the large ring and the 12 or 11 cog then shift to the small ring, Di2 will shift the rear to get out of the 11 or 12 tooth cogs. Depending on the Di2 version and the range of the rear cassette. I think if you have a 11-26 it will let you go into the 12 and 11 cogs. So maybe that's the ghost shifting the OP is talking about.
Also, Di2 will shift multiple cogs on the rear with a button press if you hold it down. I think this can be disabled and also the timing can be changed too.
Why don't you use full synchro? I have used nothing else since about 3 or 4 months after getting Di2.
ignominious poltroon
Quoted: 2281 Post(s)
Liked 3,503 Times
The "brain" is in the battery. If they went to the trouble to warranty-replace stuff, presumably this is a legitimate issue. They might need to warranty-replace the battery.
But if it is simply a matter of unexpected syncro-shift behavior, turn all that off and see if the problem goes away.
bettershifting.com is a great resource. Start here
Bikes: yes, i have one
Quoted: 1151 Post(s)
Liked 1,193 Times
spelger
Liked 4,923 Times
Fully synchronized or half synchronize isn't like an automatic transmission. You still tell it when to shift. It just lets you not have to worry about when to do the chainring shifts and moving the rear up or down two or three cogs.
You only have to use the right shifter. You could program paddles on the left or FD shifter for something else if you wish.... I think.
Quoted: 4566 Post(s)
Liked 5,097 Times
For sure that could only ever happen if the front mech actually powered up and moved over to the big ring. Whatever happened when you went over a bump triggered a full front shift. Probably bumped your hand into accidentally triggering the shift. Rear ghost shifting could potentially occur with an indexing issue, but not the front jumping little to big ring.
Liked 1,193 Times
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 161 Post(s)
Liked 139 Times
I have 6800 series Di2 on my bike and once had a sticky right-side shifter. It still shifted and released but not as crisply as the left one. A few sprays of contact cleaner fixed it.
Liked 4,923 Times
Quoted: 1284 Post(s)
Liked 1,405 Times
my money is on bumping the shifter with a hand. can’t imagine any other kind of ghost shift on the front derailleur. it’s hard to move the FD against the motor.
Liked 3,503 Times
I suspect (as do others) that the "ghost-shifting" is unexpected normal behavior. That is why I suggested turning off syncro-shifting for diagnostic purposes. However, on my wife's bike, even with syncro turned off, it won't let you cross-chain between the small-small and small-penultimate small gears, but if you try that, and then up-shift the front, it will subsequently "ghost-shift" the rear.
Liked 4,923 Times
Another thought on the ghost shifting might be that the OP has the versions of Di2 that has the buttons under the tops of the hoods and they've been enabled for shifting. If you don't know they are there you'd never tell it without stripping the hood back.
Mine are set to work my Garmin GPS. Sometimes a bump with my thumb resting on top of the hood and my screen changes.
Likes For Iride01:
I recently bought a road bike with Di2. I've has a recurring problem with ghost shifting. Occasionally, when I hit a bump my chain shifts. It usually happens on the rear, but has happened on the front twice. Front is little too big. Back is usually up to a larger cog. I'm going to verify it's not me accidentally hitting the shifters by doing a ride completely on the drops. But has anyone else experienced this?
Quoted: 3316 Post(s)
Liked 2,151 Times
JamK- I did figure out what the problem was. I was riding with my index finger along the brake. And at random times when I hit a bump my index finger would hit the shifter just enough that it shifted. I thought that could be a possibility early on but I thought I ruled it out. But when I really paid attention that's what it was.
Likes For UFIbikes:
