Gear ratio
Gear ratio
hello, im currently using 46/17 as my gear ratio. but when i try to skid its really heavy. and im thinking of changing the ratio to 46/18 or maybe 46/20, is it a good idea? what do you think?
Quoted: 4227 Post(s)
Liked 2,491 Times
Likes For wolfchild:
Veteran, Pacifist
Quoted: 3941 Post(s)
Liked 4,940 Times
Skinnier tires, not new gears.
700X19 skid better but leave a smaller mark.
Brakes only if you desire greater safety.
Darwin Award candidate?
Likes For SonoharaRevina:
Habitual User
Quoted: 5108 Post(s)
Liked 8,422 Times
I suspect this should have been posted in the singlespeed/fixed gear section.
One thing to be aware of is how your gearing will affect the spots on your tire where you are burning away tread during a skid. Since your crank position will always be essentially the same while skidding (right crank back and horizontal-ish, most likely), some gear combinations will result in less possible spots on the tire at that crank position. Other combinations will provide more. I don't know what the specific answers are, but this is a topic I read about a little while back regarding setup of "tracklocross" bikes. More spots is preferred to spread the accelerated wear of the tire over a greater area. It's something worth researching, IMO.
Quoted: 833 Post(s)
Liked 1,981 Times
There is something remarkably Freudian with someone that is concerned with skid marks.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
You should post the question in the single speed and fixed gear subforum, or the fixed gear freestyle one.
They will tell you the same thing: skidding is kind of stupid, but do whatever makes you happy.
Quoted: 2743 Post(s)
Liked 492 Times
Ironically, arguably the best gear ratio, 48-16 (the stock ratio) only has 1 skid patch.
Habitual User
Liked 8,422 Times
https://www.bikecalc.com/skid_patch_calculator
