Cycling to running miles conversion
Quoted: 2731 Post(s)
Liked 488 Times
How many miles cycled do you think it takes to equal 1 mile ran? In terms of difficulty, workout, time elapsed, or however you wish to compare. I think maybe 8 miles cycled = 1 mile on foot
Quoted: 7087 Post(s)
Liked 11,203 Times
Likes For Koyote:
Quoted: 3999 Post(s)
Liked 7,490 Times
N * sin (2 π t) *exp (- µ t) / sqrt (1 + t^2)
where t is the effective time, µ is Moehper's coefficient, and N is the meteorological distance. But it's only an approximation, good to 0.1% at best.
Likes For tomato coupe:
Quoted: 4547 Post(s)
Liked 5,060 Times
Well if you run at 6 mph and ride at 18 mph then it is about a 3:1 ratio in distance. But in terms of energy used I would think the ratio is considerably higher. I can comfortably ride 100 miles at 18 mph, but I certainly can’t run 33 miles at 6 mph. I don’t do running, but Strava would probably provide a ballpark energy consumption per mile, which you could compare with your cycling consumption.
Liked 5,060 Times
For me as a cyclist who doesn’t run, a marathon would be a LOT harder. But a lot depends on how fast you ride. Running has a much higher minimum energy demand than cycling unless you are climbing a steep hill. Riding 100 miles on the flat at say a leisurely 12 mph is not very challenging. But at 20+ mph it becomes a lot harder. Running a marathon is hard work at pretty much any speed above walking pace.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,327 Times
Purely unscientific, but I've done 1 century and 3 marathons. How I felt after the century and the marathons was similar. I've done many half marathons and while I've never gave it much thought, I guess I guesstimate a half to be about 55 or so miles on the bike. One thing that is common to all those activities is I usually enjoy a beer afterwards.
Liked 7,490 Times
Quoted: 386 Post(s)
Liked 294 Times
I cycle 19 miles to work every day in a little under 1:40, including traffic and stop lights and such. An elite marathoner can do 26 miles in a hair under 2:00. It burns me up a little inside that there are people who could beat me to 19 miles without a bike.
Likes For ScottCommutes:
I am potato.
Quoted: 1806 Post(s)
Liked 1,671 Times
There is no comparison.
Wait, there is. It's just that time, miles, and speed fail to really capture it well and the results are so easily skewed so as to be effectively meaningless.
Running is harder. The minimum energy expenditure to run, not jog, but run is much higher than sitting on a bike. Something on the order of 100-120-ish calories per mile. To "run" a mile with reasonable enough form to actually be "running" takes ~8 minutes or so at the slowest possible pace. An hour would take you 7.5 miles and about 750-900 calories.
The same number of calories expended on a bike might very well be a personal time trial of 30+ mph average speed for an hour. Impossible. A more reasonable 18-20 mph speed is (off the cuff) ~8 calories per minute equals a depressingly low 480 calories per hour. It would take about 1 hour 45 to 2 hours of reasonably high effort cycling to equal runnings 750-900 calorie expenditure. So...36-40 high effort cycling miles in 2x the time running takes to do 7.5 miles. 40 miles in 2 hours is awfully fast.
All variable and subject to externalities, of course.
I've been told that a 4 hour marathon (slow) is about equivalent to a double century. I don't know if that is true or not. The math suggests 3500-4000 calories to do a marathon depending on fitness. Personal experience of ~7500 calories measured for a double century in 3-4x the time is close enough to be plausible from an "effort x time" perspective.
Useful? I'm not sure.
Likes For base2:
In terms of difficulty: 20 miles cycling is 1 mile running.(but you still won't hurt as bad by cycling) Aand why in hell would you run?
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 412 Times
I avoid running (not a fan)but I'll cycle for miles/hours. However, I'll skate for hours....does that count.
Quoted: 1955 Post(s)
Liked 2,199 Times
A lot depends on whether you are going downhill.
John
John
Likes For 70sSanO:
Quoted: 3260 Post(s)
Liked 2,573 Times
I'd say the best way to find out is to go to the local HS/MS track........and run a mile or two. That should give you a starting point. I've ran 18 marathons since 2013. Let me think about it and get back to you.
climber has-been
Quoted: 3538 Post(s)
Liked 3,693 Times
Some estimates from the science folks, for a 150 lb. person:
Running at a 6 min/mile pace consumes 1145 Calories per hour, and the runner covers 10 miles. 1145 Calories / 10 miles = 115 Calories/mile
Cycling at 20+ mph consumes 1145 Calories per hour, and the cyclists covers 20 miles. 1145 Calories / 20 miles = 57 Calories/mile
Cycling at 20+ mph is metabolically just as "hard" as running a 6 min/mile pace, but cycling gets you twice as far.
Likes For terrymorse:
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 261 Post(s)
Liked 380 Times
I've done both and I assure you it is much easier to cycle 100 miles than to run 26. I've completed five marathons, all between the ages of 38-40, and four centuries, all in my 70s. It took me several weeks to recover from each marathon. After my centuries, I was cycling as usual the next day.
Quoted: 18521 Post(s)
Liked 15,867 Times
I’m going to go out on a limb and say 1. After all, a ton of feathers weighs as much as a ton of bricks.
Likes For indyfabz:
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 244 Post(s)
Liked 1,045 Times
I've been using the imperial system of measurement for quite some time now, this is the first time I've heard there are bicycle and running miles. I'm curious how these compare to a standard mile, i.e. 5280'?
Likes For phughes:
Quoted: 1060 Post(s)
Liked 1,319 Times
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,051 Times
Otto
Liked 15,867 Times
Riding a century is far easier than running a marathon. Anybody in good shape can ride a century every day forever.
The record for daily cycling is 240 miles every day for an entire year straight. Running a marathon every day for a year has been done but it's on a whole other level. Let alone 2.4 times that distance.
Likes For Yan:
Liked 2,573 Times
