Slime. How much to you trust it?
I have fat tires on a fat bike with the tires loaded with slime. I don’t carry a tire repair kit. How much would you trust it?
Momento mori, amor fati.
Quoted: 6330 Post(s)
Liked 4,918 Times
I haven't flatted in three years other than when my tires were worn down to the threads. I don't use Slime or anything else. Just tire and butyl tube. I still have a tube in my bag just in case.
It's not a matter of trust. It's just a matter of how often you flat. And whether or not it's a big deal if you do flat while out and about.
Quoted: 455 Post(s)
Liked 485 Times
Back in the 90s, I used slime inside of inner tubes and it worked really well against thorns. But I would never ride without a repair kit (spare tube, pump). Think about the scenario in which the puncture is too big for the slime to seal - what would you do in that case, would you prefer that over carrying a repair kit?
Bikes: Vintage Raleigh and more modern Roberts
Quoted: 57 Post(s)
Liked 160 Times
I had Slime filled tubes fitted for a ride along some English canals just after the hawthorn hedges had been cut and when I removed the tubes there were 15 holes in the rear, 9 in the front and I had kept going with nothing more than topping the pressure up. Having said that I would not go far from home without a spare tube, I am not sure how well a patch would stick to a hole with Slime oozing out of it if needed.
Likes For Small cog:
Liked 3,088 Times
slime couldn't prove to me it could do as expected.
-Oh Hey!
-Oh Hey!
Quoted: 833 Post(s)
Liked 1,972 Times
So going by the Slime website for a 2"x29" tire I would need about 7-8 ounces per tire.
Perhaps that 7-8 ounces per tire would be better suited for a more robust tire?
Likes For CAT7RDR:
Quoted: 571 Post(s)
Liked 605 Times
Down here in Southern Arizona everything has thorns and I found slime might slow a small leak but not repair, you still need to find the leak and patch, which is now often a mess. I also tried it in a pneumatic hand cart tire and it has slowed the leak but not repaired so maybe it would allow you to get home for patching in some cases.
Quoted: 642 Post(s)
Liked 409 Times
I tried slime in the eighties and found that I liked Tuffy strips better. I currently prefer more robust tires. You having a fat bike, this might be more of a problem.
I am potato.
Quoted: 1808 Post(s)
Liked 1,674 Times
I've never known any one who had a positive experience with Slime, including myself. It is just a mess and if it does what it says, I've never seen it. It's just a proper mess. It doesn't stop the leak. It oozes between the tire and the tube coating everything in a slimy stink. In addition to not stopping the leak & stinking up the place, it also stops patches from sticking so you are worse off than when you started.
It is good at clogging valve holes. So, there is that if you don't like adding air to your tires every once in a while.
In short I do not trust it at all.
Product rating: -10 of 10
(It would be 0 of 10 but it actively does the opposite of what it claims.)
Car dependency is a tax.
Likes For base2:
Clark W. Griswold
Quoted: 4451 Post(s)
Liked 4,115 Times
Not at all, maybe if it was a tubeless set up and it was the slime tubeless sealant I would say sure but the slime they use for motor vehicles not at all. Basically if I was using tubes I would just use normal butyl inner tubes and keep them properly inflated and if I was really getting a lot of flats I would consider Tannus inserts if I was keeping tubes. Otherwise I would just go tubeless and use a good tubeless sealant and carry a tube just in case and hopefully never need it.
Slime is a product that makes a gooey mess and usually doesn't do much. You couldn't really pay me to use it.
With a mighty wind
Quoted: 1114 Post(s)
Liked 912 Times
I started a thread last year about this. My position was that it worked well for low performance and low maintenance tires. To me, that’s the kids bikes, stroller wheels, and I’m pretty happy with it on my cargo ebike, when using extra thick tubes.
It’s not appropriate for being a long way from home or places you can’t walk out of.
It has its place. I’m certain that I have not bought my last bottle of slime.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2663 Post(s)
Liked 5,861 Times
One good sidewall cut - which happens - and your Slime will gush out and you will be stranded. At the very least carry a tube, pump and a dollar bill as a boot.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Cantilever believer
Quoted: 559 Post(s)
Liked 1,932 Times
My experience is that Slime treats a valve like a hole in the tube (which, technically, it is), and eventually clogs up the valve mechanism to the point that the valve itself is a slow leak. Presta or Schrader.
My wife used Slime in the tubes on her cruiser. One night she had an unexpected front blowout and came home looking like an (angry) extra from a Ghostbusters movie.
When I patch tubes for nonprofits, I consider sealant in the tube to be a strike against the tube, as these tubes can test fine but develop slow (or fast) leaks later.
I would never trust any sealant-filled tube sufficiently to not carry a spare and a patch kit.
An acquaintance of mine uses latex sealant in his tubeless mountain bike tires, and really likes it. But he still carries patches and boots.
I carry an extra tube regardless of the tire set up. Especially off road. other than usual punctures, a side wall can get sliced, a valve can get damaged (yes, it's happened)
All of these solutions are good and undoubtedly reduce punctures. But there's no way I'd go any distance without a backup. It's always possible to get a hole too big for slime to fix.
Edit: I should say reduce flats, since technically they don't actually reduce punctures, just mitigate them.
Quoted: 354 Post(s)
Liked 124 Times
I tried the MUC off no puncture inner tube sealant which is similar to slime. It clogged my valve on the second day and caused a slow overnight leak for 2 days. But after reinflating several times, the valve cleared itself.
But somehow a slit appeared on the tube and was splitting. I think it was a manufacturing defect. I replaced the tube and stopped using the sealant.
When I use Schwalbe tires with greenguard, like the Marathon, I've never gotten punctures in the first 2 years of use.
Likes For tomtomtom123:
Quoted: 833 Post(s)
Liked 1,972 Times
The Green Guards, after two years, have had zero flats and certainly should have with the $#!^ I have run over.
52psi
Quoted: 790 Post(s)
Liked 802 Times
My experiment has begun. Just loaded up the kids' tubes with Flat Attack tire sealant (4oz per tire, two bottles, total cost at the LBS $26) and we'll see how that goes. I'll never use the stuff for my bikes, as I can repair on the road in minutes. But a puncture is a much bigger deal in their world. 26" MTB and 20" BMX will be our subjects, with a routine history of goat head punctures that I get to patch. I'll report back.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,328 Times
I commented once how many years it had been since I flatted and soon after had a flat within two blocks from home as I was heading out. A similar thing happened when I mentioned I've never broke a chain. I'm never going to tell anyone I've never broke a spoke.
Likes For Chuck M:
Quoted: 1610 Post(s)
Liked 1,800 Times
No experience with Slime on bikes, but I have used Slime on 3 different occasions (I am hard of learning) on my cars. It failed to seal the leaks on all three of those occasions. No Slime anything for me any more.
Just go with the tried and true tubeless set up and forget about these half ash measures.
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
I patched a tubular tire puncture with slime. The next day I pumped it to full pressure then bent over to get a close look. At that moment the slime blasted out of the puncture and directly into my eye. No more slime.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
Quoted: 4857 Post(s)
Liked 4,001 Times
Stuff happens. A large enough and sharp enough object can defeat any slime you would ever want to put in a tire and ride. I insist on having the capability to get me though such a cut, repair the tire to rideable and inflate several times. Or stay within walking distance or cell phone range of someone who will pick you up without adverse consequences.
Likes For 79pmooney:
