Opinions on Surly front rack
When I bought my Surly the seller threw in new front and rear Surly racks. I’ve always used Tubus racks, I like the rear but the front looks like overkill. Anyone one use the Surly front rack?
Semper fi
Semper fi
Likes For sloar:
bicycle tourist
I have one on my Trek 520. Occasionally use the capacity of the rack such as this instance where I put a bear canister on top.
Depending on how much you carry and where, it could be overkill.
Likes For mev:
Quoted: 3507 Post(s)
Liked 1,491 Times
I had a Surly front rack, used it for two tours. Removed it and donated it to a bike charity. Replaced it with a Tubus low rider rack. On one of my touring bikes, I also put a tiny little platform rack on the fork that mounted on the canti brake posts, so I had both a small platform and low rider.
I have a Surly rear rack, also used it for two tours. Decided to use a Tubus or Racktime instead for tours. But I still have the Surly rear rack, use it on my heavy touring bike for riding around near home, it has a wide platform that I like for non-touring uses. But for touring, I like the Tubus or Racktime better and I think the Tubus is stiffer than the Surly even though there is twice as much steel in the Surly as the Tubus.
Quoted: 18526 Post(s)
Liked 15,873 Times
IIRC, the front was over 3 lbs., at least when it was first introduced. I you don’t need a front platform, I would definitely ditch it.
Quoted: 642 Post(s)
Liked 409 Times
I just replaced my Tubus Tara with a Tubus Grand Expedition rack so I could have a top platform for some bulky items. It weighs 27.5 oz. I also looked at the Surly front and the old man mountain Divide. I chose the Tubus because I like the 5 point mounting system and I Got a nice price. I believe I can keep the weight within their recommended 39.6 lbs most of the time ha ha.
Clark W. Griswold
Quoted: 4451 Post(s)
Liked 4,116 Times
Surly racks are good racks just super duper heavy. My Surly Nice Rack (rear rack) weighed more than 3 Tubus Racks combined (1 Cargo EVO and 1 Duo which is technically two separate racks) For me I don't hate a front platform but Surly racks are just too heavy for not being way better than Tubus. If say a Surly rack could hold double the weight of Tubus and I needed to carry that much then sure but honestly I would rather have the security and piece of mind from Tubus that comes at a huge weight savings. It is not that Surly is bad in any way beyond weight, they aren't but Tubus is specific in their support for touring.
For me I would go with a Nitto M12 or M14 or whatever for my rando bag or maybe a Rawland Ti rando rack or something along those lines. If I needed rack and panniers probably Tubus with their Grand Expedition rack but I really don't need both most of the time.
Liked 15,873 Times
I have the Nitto Big front and rear racks. Nickel plated steel. Still working and looking great after 12+ years of touring and commuting use.
Likes For indyfabz:
Liked 1,491 Times
I picked up a used Nitto rack at a swap meet to put on my titanium bike, I was surprised how heavy the rack was, it looks so light. But the steel in it is deceiving. Other than weight, I really like the Nitto rack for light duty use, but that model is not designed for touring. I use this rack for around town use, but when I tour on that bike I put a Racktime Addit Rack on it instead.
Photo below, Nitto rack with my gym bag that is a small pannier.
The Racktime I use on that bike for touring, below.
I liked that same design front rack came on Trek 520s (but don't know if same material), didn't buy one when they were for sale, but thought it looked like a great turn-key ready tourer, with that, and a rear rack with wide deck and lower tier for panniers. 3 lbs is heavy if aluminum (edit: not, it's steel, and 10mm tubes and not solid rod, that's stiffer and stronger for the same weight), that means stout. For me, you can't have too much rack space, so the top platform would be a plus, although I ride a 20" wheel folder so the space above the front rack deck is huge, I can rest large parcels there and strap to the rack and stem riser. I don't have a Surly but they have a reputation for tough stuff.
EDIT: Surly site says that is "chromoly", so moderate strength steel, that'll be stout, and at $140, a lot less for that size a rack than competing high quality steel racks I have seen. I have a Blackburn TRX-2 rear rack that is from aluminum and almost exact same weight, which is a lot, but that Surly rack holds a lot of volume for a front rack and has a weight limit of 70 lbs (enormous on just the front) versus my rear rack of 40 lbs. If you're doing an expedition tour, heavy cargo, far from replacement parts, racks are often the failure point if not designed for the load, so if hauling that much on the front, and other racks not rated for same weight, I'd go the Surly.
Quoted: 140 Post(s)
Liked 81 Times
Never used one but if I did it would probably be on a bike with mtn bike sized tires and very heavy loads. Can’t imagine wanting to tour with more weight than a 1 lb platform rack or 1 lb low riders could carry. For me I’d put it on a utility bike.
(above) Definitely expedition strength. However, for max rated weight, I think those two attachments per side on cantilevered brackets is a bit weak, I would want additional anchors at the fork crown and the canti brake posts or both, unless this would constitute "overdefined", and the anchor points changing position with respect to each other due to fork flex, putting undue stress on the rack.
Liked 1,491 Times
I commented above that on one bike I have a low rider rack (Tubus Ergo, now discontinued) and a small platform rack. The platform rack was sold by Nashbar. Photo is 12 years old. I like this much better than the Surly that it replaced.
I have the Tara for a different bike, but I like the Ergo better.
If you have canti brake posts on your bike, Sunlite also made a small platform rack similar to the Nashbar one.
Liked 1,491 Times
I do not recall if I had mentioned this to you before or not, but you can accumulate a lot of dirt on the S&S couplings in the threads. I stretched some inner tube rubber sleeves over the ends of my S&S "nuts" to keep the dirt out, as you can see in this photo.
I initially used electrical tape, but it was a huge hassle getting the tape wrapped under my cables, so no longer use that, but this photo shows why I want to keep crud out of the couplers.
Quoted: 642 Post(s)
Liked 409 Times
Tourist in MSN: Thanks and you have but, you hadn't mentioned the electrical tape. at the time. I don't have the cable problem and had tried the pieces of inner tube once. I have disassembled, cleaned and greased the couplers three times in over 10 years. I am going to try out the electrical or silicone tape. I used friction tape were I zip tied my Click-Stand bracket and my Stompump bracket to the seat tube and seatpost. The zipties alone don't keep them from rotating on the round tubing.You didn't give your thoughts on the rack. With supplied rack hardware the rack wouldn't install. If you look at the low ryder mounts there is a Tubus rear rack accessory bar screwed in then the rack attachment point attached to it.
Liked 1,491 Times
I think that rack is overkill, but if you want both a platform and pannier mounts, I see nothing wrong with it. And if you are happy with it, that is what matters. As I noted above, I started with the Surly front rack, but after two tours, ditched it for something less weighty and more compact.
Bummer that it did not fit correctly on your fork, but with five mounting points, as long as the supplied hardware worked well for the fork crown and at the dropouts, the mid fork mounts are probably not that critical.
That is a beautiful bike. I do not recall, is that the Pangea? I considered buying the Pangea, but bought the Thorn Nomad Mk II instead, mostly based on price difference. And I wanted chain drive, not belt. The Nomad is chain only. And I have been very happy with the Nomad Mk II. It is a very heavy bike but where I needed it to perform, it was great. And the frame also works with a 100mm suspension fork, which I have used a couple times on it.
Very nice looking setup. I'm puzzled by the front low-rider position being aft of the steering axis, weight there alone is less stable, it will try to make the bike steer away from a bank instead of into a bank (the latter more self-correcting), but if in balance with the higher load forward of the steering axis, great.
Quoted: 642 Post(s)
Liked 409 Times
Tourist in MSN: You are correct it is the Co-Motion Pangea, their 26" single. I had looked at the Thorn but wanted the belt. The Tubus Grand Expedition is 27.5 oz. As I stated earlier in this thread, this rack is lighter than the Old Man Mountain or the Surly. The lowryder mounts were about 1" off, so I used that rack accessory. The rack is still a 5 point mount and very solid. I need the top deck for some closed cell foam pads that I want to use in addition to my air mattress.
