both side of my bb are reverse threaded?
Bikes: jacobs
I just got back from the bike shop, where I attempted to install a bottom bracket in my new custom frame and the mechanics at the shop helping me said both sides of my bottom bracket are reverse threaded. I guess they don't make a bottom bracket for this?
He said It can be fixed if I have it switched to italian thread. Any suggestions? I just want to ride it.
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
How about an Italian-threaded BB put in the wrong way, and an English-threaded adjustable cup on the other side? Both would be "backwards" (i.e. tighten the same direction as pedals) then, would they?
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
If you have LH threads on the non-drive side, then you're out of luck if it's a regular fixed-cup on the drive-side, and adjustable cup on the non-drive side BB. However, if you're using cartridge bearings, then you might be able to find something which has LH thread for the non-drive side. Perhaps that's what your LBS was trying to say.
- Wil
Quoted: 2027 Post(s)
Liked 1,099 Times
If the mechanic is correct you have a major issue with the custom frame builder because he really screwed (pun intended) up.
Erstwhile Trogon
One of two things - either your LBS guy does not know what he is talking about or the person that built your frame did something really stupid.
Assuming it's the latter, I would get on the phone immediately and work it out. It would be completely foolish to try and jury rig some solution to a screw-up like this. You paid for a custom frame and it should be built properly. I had a similar experience with a custom in which they did not tap the BB deep enough for a standard Campy BB. It went back in the box to be repaired, shipping paid in both directions.
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Quoted: 8 Post(s)
The size of the Italian and English BBs are quite different. Go back to the builder and find out what BB he tapped for. Check out Sheldon Brown's site for the exact answer.
Bikes: jacobs
Quoted: 145 Post(s)
Liked 166 Times
If the framebuilder has a problem with whoever supplied him with the bb shell, he should take it up with THEM. As for you, he owes you a frame with a properly threaded bottom bracket shell.
And I sure wouldn't settle for Italian threading in your custom frame. There's a reason even Italian-made frames use English threaded bb's these days-
Composed Mainly of Beer
Bikes: Surly CrossCheck, Centurion CompTA, Schwinn Mirada
