Trailer hitch: should I install 2" next time?
My family car has had a 1.5" hitch for a long time, and I recently bought a Thule bike rack that only comes in 2". Next time, should I try to install 2" hitch? The U-Haul hitch did come with a 1.5"-to-2" adapter, but any additional part means possible malfunctioning, so I'm wondering if it'd have been better if I had a 2" hitch to begin with.
climber has-been
Quoted: 3605 Post(s)
Liked 3,795 Times
Bikes: Bridgestone RB-1, 600, T700, MB-6 w/ Dirt Drops, MB-Zip, Bianchi Limited, Nashbar Hounder
Depends on how many bikes. Our new Sienna 2012 gets the class 3 hitch in 2 inch. Beefy and sturdy. I put the 5 bike Allen rack. But the new Prius V we just go has a class 1 hitch and we get the Allen 3 bike rack for a 1.25 inch hitch and usually only carry 2 bikes on that. I avoid the adapters because it introduces more play as well as extends the cantilevered distance on the hitch. If tounge-load isn't the issue and the adapter is just making the connection a little loose, I think Curt Mfg. sells a strap with vinyl coated hooks that grips the trunk lid and goes around a vertical support post for most racks and prevents most vertical slop that would cause the bikes to really go up and down when driving over bumps and dips.
I believe your primary concern should be the max. tongue weight limit of your hitch. The minimal amount of sway that may arise do to any addaptor use should be a secondary concern. With a little imagination one can eliminate the swaying, but nothing can increase the tongue weight capacity of your hitch.
Bikes: 2012 Cannondale Flash Alloy 2 (mountain bike), 2010 Schwinn Paramount Series 7 (road bike)
My wife and I just got hitches on our vehicles. After very little debate we decided on the 2" hitches. I have a '12 Jeep Wrangler Rubicon 4dr and she has a '12 Subaru Forester. We also purchased a Thule rack which has a 2" insert. It's very stable and doesn't move around a bit.
IMO, go for the 2" if you can.
Where can I find the tongue weight? The hitch I have is this: https://www.uhaul.com/Locations/Trailer-hitches/837067 Is the maximum weight of 3,500 lbs the tongue weight capacity?
But what about the adapter? Do I need to worry about the max tongue weight of the adapter too, or does it all come down to the max tongue weight of the hitch? BTW, my bike rack - Thule Apex swing - is probably as heavy as bike racks get. I've got this adapter: https://www.uhaul.com/MovingSupplies/...apters?mid=313
I found the installation instruction, and it says the max tongue weight is 300 LBS. So, this should be enough to handle the Thule Bike rack, which cannot possible exceed 300LBS with my family's bikes attached.
I doubt you're going to overload a hitch with bikes and a rack. Do you have anti-rattle hitch pins? They'll stop horizontal and probably most vertical play in the connections.
I have a 2" Reese 4 bike hitch with welded in anti-rattle bolts inside it. It has a 2 inch ball on the end of it that I use to pull a trailer carrying other toys. I adjust the trailer load backwards to ease the vertical load on the extended ball. My hitch takes 500 lbs at the vehicle.
The 3000-3500 lbs is the pulling capacity. But that's determined by the lower value between the vehicle and hitch capacities. One might be higher than the other. If your car isn't tow ready I wouldn't pull something that heavy at highway or interstate speeds. I probably doesn't have the vehicle weight, cooling capacity, or braking capabilities; which can lead to handling and stopping problems.
Quoted: 5234 Post(s)
Liked 3,609 Times
haven't measured mine yet, do I measure the inside of the empty hitch?
you can fit 1.5" stuff in a 2" square tube, just need the square shim tube between the 2 {a 1/4" wall squaretube)
locking pin would pass through both the receiver , the shim and the rack of course so its still solidly attached..
Just for your own 'Peace of Mind' you might weigh your rack and your bikes, and then call U-Haul to verify that your adapter can safely handle the total load.
To answer your question regarding future hitch purchases, I always make it a habit to install the strongest hitch available for my vehicle and I gravitate towards Class III / 2" receivers and then adapt down to 1 1/4 if need be. That being said not all vehicles are rated for heavy duty towing and Class III / 2" receivers are not available for all vehicles. For example my wife's '96 Camry has a Class II / 1 1/4" receiver with a Max. tongue weight of 300 lbs. The Class III / 2" receiver on my S-10 has a max. tongue weight of 350 lbs. They both work sufficiently well for my uses.
I posted the OP but am adding the following link for posterity's sake. According to it, adding an adapter decreases the tongue weight maximum by half. It makes sense from physics perspective, although I never took physics after high school.
https://www.etrailer.com/faq-hitch-adapters-extenders.aspx
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
Your tongue weight is generally but not always around 10% of your gross weight. As said, it depends a lot on your vehicles capabilities as well. If your hitch capabilities exceed what the car can handle default to the car's specs.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Liked 3,609 Times
they have stronger 1 1/4" hitches, class II and I think class III maybe too. personally I would stay away from the whole adapter thing
Other Worldly Member
Quoted: 194 Post(s)
Liked 136 Times
After using a Thule 4 bike rack that was a heavy chunk of iron...I now have an aluminum Kuat Alpha 3. What a difference in weight. Two road bikes (18 and 23 lbs) and an MTB (32 lbs) plus the rack (13 lbs) wouldn't go over 90 pounds total. Three light road bikes and you'd be at ~60 pounds total.
Make ******* Grate Cheese Again
Liked 3,609 Times
no I have not but I think wobbly is a bad sign. can you return the bike rack and get another made for your size hitch? probably 1.25" not 1.5"
