Roadside Tire Repair
climber has-been
Quoted: 3509 Post(s)
Liked 3,652 Times
After getting stuck with a damaged tire last year on Mt. Hamilton, 12 miles from my car (thank you, Good Samaritan, for picking me up), I determined to not get stuck in the same situation. Fool me once -- you know the rest.
I added the following items to my saddle roll:
The fix worked like a charm. I was expecting to see a bulge in the sidewall when inflated, but the combination of nylon and super glue was enough to keep the hole from opening up at all. I can hardly tell where the tire was damaged. I was able to complete the descent at normal (fast) speed.
Any way, if your travels take you to places where a tire failure means a multi-hour walk in bike shoes, I recommend adding something similar to your repair kit.
- 3" x 3" square of ripstop nylon
- teeny tiny scissors
- tube of super glue
Likes For terrymorse:
Quoted: 7062 Post(s)
Liked 11,130 Times
I just carry these.
Likes For Koyote:
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2693 Post(s)
Liked 3,243 Times
I use a strip of old tire, bout 1" x 3", with the bead cut out
"Your beauty is an aeroplane;
pan y agua
Quoted: 1459 Post(s)
Liked 736 Times
Duct tape
You could get lost and die.
You could hit a tree and die.
Bikes: yes, i have one
Quoted: 1147 Post(s)
Liked 1,187 Times
is this a special thing for tubeless? for tubed tires i use paper money. when i don't have that (very rare) i'll plan on looking around for some paper blowing in teh wind because we humans are dirty pigs paper is bound to be easy to find.
normally i'd agree with the duct tape. i'm using that on a tire that i crashed in for my trainer. it bulges a lot. would not be save to ride on.
Quoted: 20810 Post(s)
Liked 9,456 Times
Liked 11,130 Times
Yep, currency is very strong. I once used half a dollar bill (so it only cost me $.50 -- ) to temporarily boot a gashed tire while out on the road. Finished my ride and forgot all about it. A couple thousand miles later, when the tire was completely worn out, I replaced it and found the half dollar bill. It did the job beautifully.
Quoted: 4845 Post(s)
Liked 3,974 Times
A third on paper money. I try to carry at least 5 bills. I've used several for large gashes. But I cannot see using half as bill. Fold it over and spend it when you are done! I've laundered them after. Yes, I know that's a federal crime but no one's complained so far about getting clean dough.
Quoted: 474 Post(s)
Liked 1,076 Times
I just carry these.
Quoted: 569 Post(s)
Liked 596 Times
Kinda weird but I and now all in the family carry a dollar bill size or larger piece for larger tires cut from a hazmat suit. A little rougher surface than a dollar bill and lots stronger, seals and holds up very well.
climber has-been
Liked 3,652 Times
I just carry these.
They don't hold the tire gash closed very tightly, so if the hole is on a part of the tire that touches the road, the boot wears through in several miles.
I like my ballistic nylon/super glue patch better, as it holds the gash securely closed. I've ridden a few hundred miles on a tire patched in this manner.
Gorilla tape might work just as well. It's strong, not stretchy, and very sticky. But how to carry it in your saddle bag?
just another gosling
Quoted: 3910 Post(s)
Liked 1,959 Times
I simply carry a light spare tire, been doing that for many years. A spare tire solves all tire problems more quickly than anything else. Have a flat? Don't bother looking for the cause, just put on the spare and a good tube and off you go, very quickly. Do the repair at home. Of course that only works for folks who still use tubes or TLR rims and who still use light tires.
Results matter
Results matter
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 275 Post(s)
Liked 450 Times
I've used those stick-on Park boots before, but I've also had them fail pretty quickly.
climber has-been
Liked 3,652 Times
I running with tubes.
Quoted: 1425 Post(s)
Liked 1,946 Times
I don’t believe Gorilla Tape is avail in sheets - but this stuff is :
Likes For t2p:
Quoted: 3392 Post(s)
Liked 5,576 Times
I just carry these.
These work a hell of a lot better than just using a piece of an old inner tube, because the adhesive solidly holds them in place, AND they don't bulge out of the hole under pressure.
I used them twice to patch holes big enough to push my thumb through.
Quoted: 778 Post(s)
Liked 1,790 Times
I always have a couple of dollars on me that I can just put inside the tire and it keeps the tube from going through the hole. I also have a little duct tape wrapped around my tire tool so I took a little piece of the tape to tack the dollar in place and put the tube in, and I was on my way. Same concept .
Liked 9,456 Times
Sealant can be a mess but - at worst - just carefully break the bead and spill it out. With an effective sealant and some darts/plugs, that shouldn't be a problem that you encounter very often, though (unless you're riding supple tires through war-torn streets).
Likes For WhyFi:
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 377 Post(s)
Liked 475 Times
Long ago, I moved on from currency to precut pieces of Tyvek. You know, from fedex or usps envelopes. Free!
A larger sheet folds up incredibly small in my bag, in case I need chest protection for a chilly descent.
By the way, those free Tyvek strips work for a friend's cut tire, as well, rather than me coughing up a bill. lol
OM boy
Bikes: a bunch
Quoted: 539 Post(s)
Liked 671 Times
Totally, Terrymorse, gotta carry tire repair stuff - at least for workable booting.
I would guess the Park Tools patch would be good.
But I've been using Duct tape for decades, and never let down on emergency tire repairs - as long as the 'bead' hasn't been cut. Gorilla tape would be the same, except Duct tape can be 'cut' by tearing...
I wrap the duct tape around one tire lever, enough to have about 3-4 in of full width. If seems a serious cut, I'll do 2 layers of duct tape, perpendicular to each other. Never been let down by it.
TYVEK - Great idea ! I use Tyvek for many things, including as a ground sheet for my tent, when backpacking... super light, tough, tough, tough! Also thin and nicely slick - I use a sheet (USPS envelope) to help me get my foot into my Nordica Doberman Ski Boots, which are an absolute horror to get in and out of (but, oh what a fit and performance!)
section of TYVEK under duct tape - Brilliant ! TYVEK going into the seat bag, now...
Ride On
Yuri
EDIT - for emergency work, I always carry, in the saddle bag, 3-4 of those small paper napkins you get at coffee shops, to clean the hands after doing any on-road repairs - always enough space to squish a few in. Even changing tubes can sometimes be messy... it's the 'German' in me... LOL !
Ride On
Yuri
Likes For cyclezen:
Liked 5,576 Times
That is why I always carry a few disposable vinyl gloves in my tool bag.
Likes For Shimagnolo:
Quoted: 1623 Post(s)
Liked 2,650 Times
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 419 Post(s)
Liked 962 Times
FIFM:
A spare tire solves all tire problems more quickly than anything else. Have a flat? Don't bother looking for the cause, just put on the spare and a good tube and off you go, very quickly. Do the repair at home. Of course that only works for folks who still use sew-ups tubes or TLR rims and who still use light tires.
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 117 Post(s)
Liked 65 Times
I live in San Diego, and there is an unfortunate amount of glass, sharp rocks and other debris roadside. Would putting tubeless sealant in a tube help with punctures?
Cheers, Mike
Cheers, Mike
