Descending with More Confidence - Head Tilt??
Should Be More Popular
Quoted: 22767 Post(s)
Liked 9,167 Times
Those who know me are aware I am cautious with twisty descents. I am typically falling behind my friends when it gets fast and technical, especially if it’s a road I have not ridden before.
I am aware of the usual “tips” to improve cornering at speed: look where you want to go, put weight on outside pedal, push hand on inside handlebar, inside knee out and inside shoulder in.
On my recent trip to Mallorca, I seemed to make a minor “breakthrough” and gained a LOT of confidence. I was dropping a couple of my buddies who previously would have dropped me.
One observation: I seem to feel much more stable and confident if I keep my head (and brim of helmet) even with the horizon, I don’t think I did this before or if I did, I was not aware. This head tilt along with other standard tips above seems to have coincided with my improvement (unclear if one caused the other).
Any confident descenders out there have any comments or more suggestions? I still have to work on this skill but pleased with recent improvement.
Quoted: 4069 Post(s)
Liked 7,664 Times
I think that would be counter productive for high speed turns.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1280 Post(s)
Liked 1,335 Times
One thing I've noticed is that if I don't do gnarly descents regularly, it can sometimes take a while to get back into the swing of things...I seem to forget just how aggressively I can corner on a bike if I haven't done it in a while.
Since the pandemic I've been riding far tamer terrain than in typical previous years, and so lately I've been doing what I think of as "practice runs" ...solo rides ('cuz no need to take out yer buddies if you overcook a turn on a training ride, right?) where I Take A Leap Of Faith and hurl myself into a descent that I know I've been able to torch in the past...and then do it again. And again.
Cyclists talk about doing "hill repeats" all the time, and yet how many folks work on hill repeats downhill? Practice helps.
Likes For Bob Ross:
The older I get, the more timid I have become. Also being sweaty and cold at the start of most of my descents, it has blunted my need for speed. Somehow most of my rides now starts in the early morning as opposed to midday or afternoon when I was much younger. Something about family time.
Quoted: 1175 Post(s)
Liked 456 Times
I have been more confident in my tires as of late since I have been running full tubeless on both my regular rotation road bikes. With the slightly lower tire pressure I feel that I have more options for which line I can comfortably pick through the entrances and exits through the downhill transition. Also shifting but back on the saddle or even off the back of the saddle momentarily sometimes plants the bike better as does going wide out by the middle line of the road then chosing to cut across the apex in the safest manner possible depending on the conditions.
If wearing a cap under you helmet that has a bill, you might want to flip it up so you can see better. Also, if you are aware of potholes, gravel, expansion joints, etc.. it may be a good idea to float over these obstacles by keeping your upper body loose (maintain a bend in both elbows, butt shifted back.
should be more popular
If there was one technique that I felt helped me most with cornering at speed - once all the basics are covered - it is what I call the 'hip pivot', I once found in a book "rotate your crotch on the saddle and point your hips into the turn. This is the best cornering tip you’ll ever get, and one that many riders don’t know or use."
This really opens your body in the direction of your turn, and together with looking towards the exit of the turn, it allows you to flow through like on rails. So more than opening the inside knee, it's an actual bum rotation.
Likes For yaw:
Likes For spelger:
Bikes: yes, i have one
Quoted: 1155 Post(s)
Liked 1,200 Times
Forgot to add...I do tilt my head but in the direction of the turn. I used to do it like how you described but I have far more confidence tilting into the turn and I can go faster.
Quoted: 2748 Post(s)
Liked 493 Times
I feel like fast descents are a young man's game, once you get older or have had a few crashes on descents its not as fun. 27 year old senior citizen over here.
Likes For LarrySellerz:
Quoted: 8444 Post(s)
Liked 9,396 Times
Maybe you're just an old soul? I agree with the caution as we age. I'm 69 and I don't push it on the twistys.
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 270 Post(s)
Liked 1,166 Times
I take corners like I'm on my street bike, it's more than just "shoulder in." I'm actively leaning my body into the corner in an effort to decrease the lean angle of the bike...less lean angle on the bike equals a safer turn. Before I started riding street/sport bikes, I never thought about lean angle very much...I was a fast descender, but was playing with fire. Eventually it caught up to me and I washed the bike out coming into a turn. Not all sport/street bike riding techniques cross over, as the suspension plays some role in it, but the lean angle concept has really rebuild my confidence in descending.
Liked 9,167 Times
I have this, if I have a need for speed
climber has-been
Quoted: 3605 Post(s)
Liked 3,790 Times
Whatever works for you is okay, I guess. But none of these "body english" techniques work to make turns faster.
In fact, wiggling your body parts around may make you slower. The faster you descend, the less body movement you should be doing. Think quiet and secure core, weighted outside pedal, relaxed shoulders, easy and small steering inputs, and looking where you want to go.
Likes For terrymorse:
don't try this at home.
Quoted: 989 Post(s)
Liked 537 Times
I'll go full speed if:
The roads are in good repair. No potholes, no sunk spots, and no gravel kicked out onto the road. A single large gravel chunk has caused pinch flats on two different occasions, on an otherwise perfectly smooth road. Both times, the road was straight enough that I was able to stop without falling. It's not easy braking with the back wheel only and trying to control the bike direction with a flat front tire.
I have long enough sight lines ahead. I'm slowing for blind corners way more than I used to.
Easing the pace:
I ride with a rider that has to go slower on downhills due to vision limitations. It's actually nice to slow somewhat, get a chance to enjoy the downhill. Instead of having to be "laser focused" on the road surface ahead at high speeds. I'm liking the downhills with some small braking intervals to control my speeds.
Braking distance uses up kinetic energy, which goes up by the square of the velocity.
This is an interesting video: Calculating a Car Crash
One car is moving at 70 mph. As a car going 100 mph passes it, they both see an unexpected barrier across the road, and both brake as hard as possible.
The 70 mph car just barely stops in time.
So, how fast is the 100 mph car going when it crashes? Not 30 mph. It's still going 71 mph! (They do the math to see why.)
The video surprised me. The summary: braking takes away the car or rider's kinetic energy. BUT--kinetic energy goes up by the square of the velocity! It's really unexpected, but now I notice how much longer it takes to brake from 40 vs 30 vs 20 mph.
This also means that a faster crash is going to be way worse for me.
On downhills, I want to be able to stop or be going quite slow within the distance I can see problems ahead. Yeah, "most every time" nothing happens. But.
Examples:
45 mph is 65% longer stopping than 35 mph. Wow. And the first portion of slowing down does way less to the rider's speed reduction than the remainder of the time.
45 mph is 25% longer than 40 mph.
40 mph is 77% longer than 30 mph.
Easing the pace:
Examples:
Likes For rm -rf:
Likes For DonkeyShow:
Expired Member
Quoted: 3811 Post(s)
Liked 5,824 Times
I suffer from too much "what if" to even approach cornering limits on descents. Locally, folks have been crashed by dogs, cats, squirrels, chickens, turkey and deer. I could probably have therapy to get over it but at my age it's not worth the trouble.
Likes For shelbyfv:
one of the steepest descents that I frequently ride shows close to 40mph on my Garmin. I don't use any brakes, I just coast and watch the speedometer go up, which is really fun
Quoted: 390 Post(s)
Liked 258 Times
Likes For Jack Tone:
Quoted: 1871 Post(s)
Liked 670 Times
I wouldn't say it makes me corner faster. It enables me corner with more smoothness and fluidity, since I'm more confident I'm on a path where I won't, for example, break a rim.
Quoted: 3261 Post(s)
Liked 2,582 Times
Oz never did give nothing to the tin man.......that he didn't already have.
Warning: Highly opinionated comments below. I am not the fastest descender, but per Strava, I rank in the top 5% on technical descents.
Here is a Pidcock descent:
We can see both relaxed stability (easy corners and pedalled corners) as well as crotch pointing in knee out corners, among general madness.
Road Fan another motorcycling technique with slight applicability is countersteering, that little bit of forward pressure on the inside handlebar seems to work well to measure and hold steering input.
pan y agua
Quoted: 1483 Post(s)
Liked 768 Times
when you point you knee into the turn, and open your hips into it, you’re keeping the bike more up right, and limiting the counter steering. Rotating your hips opposite is encouraging the bike to counter steer,and carve lie a ski into the turn.
But Davis, the Cash Reigister, Phinney won more races than any American in history( with the possible exception of Major Taylor) and won stages of the TDF, so not sure how much he knows.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 485 Post(s)
Liked 570 Times
I spent a number of years as a volunteer fire fighter / medic. I work as an engineer. We could probably sit around all day and we could swap horror stories about ruptured spleens from impacts, C3/C4 fractures who would have been paralyzed if we had done anything wrong, people with titanium implants in various places, etc.
At the end of the day, I ride at the speed that I feel confident. I drive my car at a speed that I feel confident. I still climb ladders. I have done all kinds of things that are truly dangerous. I have crawled into a burning building with someone on my heel and a nozzle in my hand, because I felt comfortable with the hundreds of hours of training and experience backing me up. My two worst injuries have been walking down a sidewalk and walking down the stairs in my house. Shlomo was right: Time and chance happen to all.
If you are just not comfortable with the speed, why push it. I run performance tires, I make good and sure that any ladder I am working on is properly braced. I give myself every equipment advantage I can afford. I do not go beyond my confidence level, and I don't feel bad about it.
If I wanted to descend faster I would go somewhere where I could practice descending relatively safely and turn up the intensity gradually. It is mostly about controlled experience. When you ride be aware of where road debris accumulates. Or just be happy with the speed you currently ride.
Likes For DangerousDanR:
